Whats my 389 gonna make
So, what do you think my combo will make hp wise?
389 stroker
LE Heads & Intake
GM 847 or XE 230/236
10.5-1 comp
SLP Shorties
58mm TB
30 lb injectors
and all of the other crap associated
I am trying to sell my comp cam. Supposedly it has sold on ebay, but I am awaiting his response. If he backs out, I will probably still use the comp cam.
thanks!
-Zach
389 stroker
LE Heads & Intake
10.5-1 comp
SLP Shorties
58mm TB
30 lb injectors
thanks!
-Zach
If its an A4 then kick about 20 rwhp off what i said, but ive seen LE cars with stock cubes run 410 on his small cam and LE1 heads.
With a 389, LE2 heads, 847 cam, and boltons.... id easily say 450 without a problem. Sometimes i am a little optimistic though.
450 is assuming its running prefect.
Lloyds cam will be your best bet but with a stroker, i would step up to a larger duration cam if i were you! i'm sure Lloyd has something he can get you
remember a larger cam in a stroker acts like a smaller cam in a 350.....so to speak
Magenta_Hearts
Mar 25, 2015 10:24 AM
