whats a lt4 motor worth?
Old Dec 14, 2006 | 08:39 PM
Daniel6718's Avatar
if you had a chance to buy a lt4 core motor, that just needed new bearings ect what would you pay?
the reason im tryin to get one is because its already 4 bolt mains....and the lt4 heads and intake have more to be taken out of them, i plan to build it not to rebuild and stick in my car and say wow i have an lt4! it will be fully built!
any gueses welcome....
Old Dec 14, 2006 | 10:16 PM
Daniel6718's Avatar
any opinions before the morning!
Old Dec 14, 2006 | 10:44 PM
reamo04's Avatar
the LT4 block itself is no different than the corvette LT1
the only difference between LT4 and the 4bolt LT1s are the heads/intake
If i were you, id find a 4 bolt main LT1 (people wont charge as much), or even just a LT1 and get 4 bolt splayed caps
if your going to build it anyways, get something better than LT4 heads, such as advancedinduction, or LE2/LE3.
Old Dec 14, 2006 | 11:29 PM
sbs's Avatar
sbs
It's worth whatever you'd pay for an LT1 in the same condition, plus the value of the heads and intake, which is somewhere in the $1000-1500 range.
Old Dec 14, 2006 | 11:54 PM
Daniel6718's Avatar
thats what im getting at, im aware the blocks the same. the heads will be better than lt4 i said built they would be le3 lt4 heads!
i figured the intakes worth at least 500 more than an lt4 heads i had no idea, maybe 500 also, so lt1 plus 1000, somewhere around 1500-2k as a good core...
not to mension if i build it id prolly have a lt4 cam springs and rockers and timing set for sale
LeftoverChinese
Jan 14, 2024 03:03 PM
ModdedNerd
Jan 29, 2015 07:23 PM
Jazsun
Dec 29, 2014 12:14 PM
