whats louder, lt1 or ls1?
How is aluminium a better dampening material than cast iron, at least when it comes to the sounds of combustion? F1 engines are made of aluminium, so are Top Fuel engines, they all are about 10 times louder than any LT1 on the planet.
Originally posted by Antz97ZNJ
Lt1 is much louder hence the firing order...but the ls1 is far faster
why is the firing order different due to car loudness? The reason GM switched firing order in the LS1 was for a smoother idle. All GM V8s had a firing order of 1-8-4-3-6-5-7-2 until the ls1 (1-8-7-2-6-5-4-3). Also I disagree about the LS1 being far faster. It is faster but I wouldn't say far faster.
Here is an example. I have a 1997 Camaro Z28 (LT1) and my good friend/coworker has a 2000 Trans Am WS6 (LS1). We both have stock exhaust manifolds, stock cats. We both have the same exhaust setup. Where the DS meets the ujoint we both have Dynomax Mufflers with a turndown, exact same spots, exact some muffler. My LT1 is ALOT louder then his.
Dan
Dan
