whats this hole for under the intake
Old Oct 29, 2008 | 03:08 PM
sn8ke eatr's Avatar
1993 lt1 intake,
on the underside of the manifold under where that metal oil cover goes, it looks almost like a slot for a quarter to go in
whats its purpose?
Old Oct 29, 2008 | 05:38 PM
93Z28Sam's Avatar
Positive Crankcase Ventilation
Old Oct 29, 2008 | 06:12 PM
sn8ke eatr's Avatar
does the intake create some type of vacuum or something? why is there a hole there and also the tube coming out of the valve cover going into the intake? wouldnt they both be doing the same thing?
Old Oct 29, 2008 | 06:20 PM
Air goes in through the valve cover and comes out through the intake (PCV valve).
Old Oct 29, 2008 | 06:46 PM
sn8ke eatr's Avatar
so.. air goes into the crankcase via valve cover, correct?
and air leaves the crankcase via pcv valve which is located?.. ( is it the tube coming out of the back of the intake-mines blocked off)?
so as for the hole on the underside of the manifold.. is air going from the manifold into the crankcase, or the other way around?
Old Oct 29, 2008 | 06:56 PM
Yes.
The PCV valve is in the LH middle of the intake manifold. http://shbox.com/1/pcv.jpg
Air moves from the crankcase and out the intake through the PCV. It goes through the vacuum line on the PCV valve back into the intake to be burned with the a/f mixture.
Old Oct 29, 2008 | 11:56 PM
sn8ke eatr's Avatar
ohhh alright i understand, the hole under the intake goes directly to the pcv valve. from looking at it fast i thought the hole was just a general hole going into the runner area of the intake manifold,
thanks for clearing that up,
Victor Lamb
Aug 26, 2017 02:52 PM
nikolt1
Feb 27, 2015 09:10 PM
pimpss96
Feb 12, 2015 01:28 PM
rjc1629
Jan 27, 2015 10:46 AM
formula218
Dec 2, 2014 04:27 PM
