What's the difference between Autolite 104 and 106?
Old Jan 27, 2008 | 12:52 AM
biggrizzly's Avatar
What's the difference between Autolite 104 and 106 sparkplugs?
Old Jan 27, 2008 | 02:32 AM
speed_demon24's Avatar
104 is 1 heat range colder.
Old Jan 27, 2008 | 05:52 AM
NightTrain66's Avatar
yep, the 104's are colder. I would suggets gapping them at .035 or so instead of the factory gap.
Lloyd
Old Jan 27, 2008 | 10:08 PM
biggrizzly's Avatar
Lloyd
What does the colder plug do for you? All the parts places say to use 106 stock. I have your LE2 heads and you said to use the colder plug. So why do I want to use the colder plug? I'm also using the thinner gaskets too.
Old Jan 27, 2008 | 10:14 PM
ulakovic22's Avatar
Colder plug resists detonation more on high compression engines and gapping them less is so you don't blow out the spark and you get a stronger spark for your application.
Old Jan 27, 2008 | 10:38 PM
The only difference is the temperature of the plug at the electrodes. Too hot, and the electrodes burn, too cold and the plug fouls. Higher compression/higher volumetric efficiency requires a colder plug to conduct the heat from the higher combustion temperatures, and keep the electrodes from burning. In an extreme case, too hot a plug can turn into a glow plug and cause pre-ignition, which can damage the pistons and heads, among other things. A stock engine needs stock heat range plugs.
Old Jan 28, 2008 | 07:47 AM
Wckd94Z's Avatar
106s from my experience are slightly hotter than a stock delco platinum. I was running 104s at a .04 gap prior to nitrous, and now I'm running a 103 at .035. I love autolite plugs BTW!
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
