whats the dif?
Old May 4, 2003 | 04:49 PM
DarkoStoj's Avatar
whats the dif?
whats the difference between a corvette LT1 and a camaro LT1?
Old May 4, 2003 | 05:01 PM
All Corvette LT1's were built on a 4-bolt main block. The F-Body LT1 is a two bolt block. The Corvette has two knock sensors, the F-Body has one. And of course the engines are "offset" in the model years... Corvette from 92-96, F-Body from 93-97. There are probably subtle differences on things like the exhaust manifolds, water pump and accessory brackets, required because of the "packaging" differences.
Forgot... the 'vette has an oil temp sensor.
Old May 4, 2003 | 05:04 PM
DarkoStoj's Avatar
if they were nearly the same engine, why is the corvette so much faster?
Old May 4, 2003 | 05:05 PM
Corvette had better inlet air ducting, and a better true dual exhaust. The Corvette weighs 300# less. Nothing else.. and they aren't that much faster from my experience.
Quickss96
Jan 29, 2016 05:56 PM
marc1130
Aug 16, 2006 06:31 AM
2Poor4Z
Aug 4, 2004 11:19 AM
Grn96Z
Apr 3, 2003 10:44 PM
kmook
Feb 6, 2003 09:53 AM
