whats the deal with the SLP short throm shifter
Old Nov 10, 2003 | 08:43 PM
cz28s's Avatar
Is the slp short throw shifter any good? well lets say compared a B&M and pro 5.0. any opinons, any experience? thank again fellars
Old Nov 10, 2003 | 10:56 PM
The SLP shifter is the same one that could be had as an option on the SS. It is a "cheapened" version of a Hurst Competition Plus shifter. It differs from the Hurst in that it requires you to reuse the stock shifter lever with rubber bushing.... so it still has the tendency to feel rubbery. Then the cover plate is a thinner gage metal than the "real" Hurst. And of course niether the Hurst Comp + or the SLP has shifter stops, which were added later on the Hurst Billet Plus.
I had a Hurst Comp +, compared it to a shifter that came off a spare T56 that I bought out of a 97 SS, and the SLP was not up to the Hurst. Later I swapped to the Pro 5.0, and it was a work of art compared to the Hurst, and shifted a lot better.
Old Nov 10, 2003 | 11:35 PM
Compstall's Avatar
Not sure what rubber bushing you're talking about but mine never had one, and I don't know where it would go?
The SLP shifter is a great upgrade from stock, and honestly I haven't felt all that much difference between it and the Pro 5.0 I have now. Sometimes I think I might have wasted $160. The Pro 5.0 is a solid piece, but I didn't get any night/day difference between them.
Old Nov 11, 2003 | 03:25 PM
Did you ever look closely at the stock shifter lever? There is a rubber bushing concentric with the shaft, at the base. It is not removable.... it is built into the space between the shaft and the mounting end.
Old Nov 11, 2003 | 07:25 PM
Stoopalini's Avatar
This guys auction has a good picture of a stock shaft with the bushing VS an aftermarket shaft with no bushing.
A buddy of mine upgraded his factory SS shifter and I now have his factory one installed in my Z. I notice a difference over the factory Z shifter, but it's not like a Pro5.0 or similar aftermarket.
If you can get a Hurst shifter out of an SS for cheap - free, then I say it's worth it; but if you are going to spend $$ on one, I would save up for a better one.
Thomas.
Old Nov 11, 2003 | 08:55 PM
cz28s's Avatar
appreciate ya! im gonna go with either pro5.0 or B&M ripper. cant decide? damn i wish there was place to test them out
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Apr 16, 2015 09:57 AM
nikolt1
Feb 27, 2015 09:10 PM
Decromin
Aug 18, 2002 10:11 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
