whats this code mean?
Old Jul 20, 2004 | 10:43 AM
dirtybird96's Avatar
I just went to auto zone because of a ses light. I've been having a lot of troublewith my oxygen sensors reading slow, and I have changed them 3 times. Anyways I get this p-1642 code and the guy can't give me a good explanation. Can anyone give me an explination of this code? Thanks
Old Jul 20, 2004 | 11:23 AM
moparman's Avatar
Re: whats this code mean?
It means there is a problem with the fan control relays 2 and 3 circuit. Are the fans coming on at the proper time?
Old Jul 20, 2004 | 11:28 AM
As far as I know. I haven't had any trouble with overheating. The t-stat usually stays in the 170-180 range.
Old Jul 20, 2004 | 12:18 PM
LWillmann's Avatar
Do you have a fan switch? If you do, that might be causing that code.
Also, you can try pulling and reinserting the relays to see if the codes come back.
Old Jul 20, 2004 | 01:31 PM
Yes I do have a fan switch, I didn't use it but I'll bet it got bumped. I'll check the relays if the problem comes back. Thanks for the help
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
