What's code 29?
Old May 23, 2004 | 03:04 AM
Jay-Roll's Avatar
What's code 29?
Car is a 95' Z28 LT1. Been having an SES problem lately. It doesn't seem to really be causing a problem, but it's annoying. Threw a code 29. It wasn't very specific of the problem, and honestly I can't even remember what it said besides the code #(we were drinkin' ok). Also we tested my EGR because as we were scrolling through everything while the scanner was hooked up we noticed it showed 0%. So we kept it on EGR and ran the rpm's up to around 5 grand or so. It never moved at all, stayed at 0%. So obviously that's not moving, good thing I'm removing it. Anyways anyone know what code 29 is? Also think the EGR has anything to do with it? Thanks in advance.
Old May 23, 2004 | 07:17 AM
There is a code list on my Tech Page. 29 is for the AIR pump. Revving the engine is not going to make the EGR operate. It only operates in part throttle conditions while you are moving.
Old May 23, 2004 | 08:08 AM
lovescamaros25's Avatar
why would it only work when your moving?i thought the egr valve supposed to work when the car is under load or part throttle,regardless of wheter the car is moving or not
Old May 23, 2004 | 11:42 AM
Well, maybe moving was not the right word. Under load, as you say, is correct. However, there may not be enough engine load when you are sitting still and revving the engine. So basically, you would be moving when there is a load.
Old May 23, 2004 | 12:01 PM
G-ZMachine's Avatar
http://web.camaross.com/forums/showt...hreadid=219753
I had DTC 29 it was my air pump.
But if your going to get rid of the EGR your probably going to get rid of the air too
Old May 23, 2004 | 01:59 PM
Jay-Roll's Avatar
Yeah I plan to remove the air pump and EGR through a tune here in a few weeks. So if that's the problem it should fix it right? Also are there any other symptoms to show the air pump is not working? I'm trying to think if I noticed anything diffferent, but I don't believe I have. Also does this code affect performance in any way? Thanks for all your input everyone.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
