whats better, stage 8 or ARP header bolts?
Old Apr 25, 2006 | 11:18 PM
  #16
firebirdStud's Avatar
Re: whats better, stage 8 or ARP header bolts?
cool, but they are still only 3/4" long, and still have the bigger 3/8" head... But, they are definately cheap! Damn 10 bucks...
Old Apr 25, 2006 | 11:27 PM
  #17
Z95m6's Avatar
They have them in 7/16 and 3/8" heads you won't get smaller than that. You also can get 1" long bolts as i've gotten them at the local autoparts store, in Mr. Gasket brand.
Old Apr 25, 2006 | 11:45 PM
  #18
Talking Re: whats better, stage 8 or ARP header bolts?
actually, arp sells them as a 3/8" bolt, 1" long, and a 5/16" head. look at part number 070-400-1110
http://www.jegs.com/webapp/wcs/store...1673&langId=-1
Old Apr 25, 2006 | 11:51 PM
  #19
Z95m6's Avatar
Hmm thats surprising that they make them that small. I thought the ARP's were a lot more expensive like 30-40+ but for that price you might as well just get them although you're gonna get raped on shipping and handling for another $10 unless you have other stuff to order. I hate that BS.
Old Apr 26, 2006 | 07:27 AM
  #20
lol well there is two guys I work with that race NHRA, and they are putting in an order too, so I get to use their racer discount, and split shipping 3 ways! Plus I am getting a few more things too.
Old Apr 26, 2006 | 07:40 AM
  #21
wrd1972's Avatar
hmm, so the arp ones are good? they are 20 bucks cheaper than those locking ones too. I used the ones that came with my rksport ones, and they worked great. They were only 3/4" long though.. The arp ones I would get would be one inch long, with the smaller head to get the box end of the wrench in there. Damnit, I hate desicions like this!
I have the ARP SS 1" with my RK's, they work great, the 5/16" hex head is easy to work with. You will need to grind a box end wrench down thin for two of the passenger side bolts.
I have had to tighten up the bolts just one time so far. The stage 8's seem like a joke to me, however the breslins seem more practical.
Old Apr 26, 2006 | 08:19 AM
  #22
Stoopalini's Avatar
I have 3/4" Stage 8s on both of my vehicle's headers, and never had a problem.
The Blazer has had them for 5 years now with Hooker Super Comp Shorties, and no leaks or backing out. I've never had to retighten them. The Z has had them for only a month or so with SLP shorties.
The trick with the Stage 8s is, when putting the locking washer on, make sure the bolt's head is positioned in such a way that if the bolt starts to back out, the washer hits a primary. If you do it this way, it is impossible for them to back out.
If they do back out on you, then the washer was installed with a gap between the flat part and the primary (if you were to spin the bolt left).
Thomas.
Old Apr 26, 2006 | 10:49 AM
  #23
hmm, interesting. From what I hear those ARPs are lookin good. Plus, the smaller head seems to be the shizznit for headers!
Old Apr 26, 2006 | 02:29 PM
  #24
bt96ss's Avatar
I used Breslin's and have had no issues what so ever. I will never use any other brand again. Once they are tight they are tight.
Old Apr 26, 2006 | 05:53 PM
  #25
Kevin Blown 95 TA's Avatar
I used ARP SS studs with 12 pt nuts. They are a little clearance challenged, but gets rid of the possibility of having a bolt not go in or stripping/crossthreading holes. They get retorqued once and stay good & tight.
Old Apr 26, 2006 | 09:13 PM
  #26
speed_demon24's Avatar
what is breslins? you don't like those either?? lol the arp's are lookin better and better by the post!
I ment to say no complaints lol, I love the breslins so far...
Old Apr 27, 2006 | 11:47 AM
  #27
should I go with 6 point or 12 point arp heads?
Old Apr 27, 2006 | 12:03 PM
  #28
383Z4ME's Avatar
Do a search the Breslins are a split header bolt with an allen screw on the inside. You tighten up the header bolt then tighten the screw inside the bolt, this spreads the bolt and locks it in place. I'm sure they work great but i could only imagine what it would be like if you rounded out the center allen screw or it was ceased in there. That Bolt would never come out.
Well you are wrong about them never coming out. The idiot who first put my headers on a '94 used the Breslin bolts I bought and he wondered how hard it would make them to get off so he just loosened one without backing out the allen screw. Then he was mysified why they come out easier than you would think and showed me on another or the same one. Imagine how the threads in my head felt though? I am sold on them though. I've used them for my '98, too.
Old Apr 28, 2006 | 07:31 AM
  #29
wrd1972's Avatar
6 point all the way cause you can but an open end wrench on the head. This wont work on a 12 point unless you are a migician.
This will help the PITA LT1 header install bigtime. If I tried to a 12 point box wrench for the passenger side bolts I would probably burn the car to the ground out of pure frustration.
Old Apr 28, 2006 | 11:14 AM
  #30
Im with ya on the frustration part! I have wanted to drive my car off a cliff several times, but now Im glad I didn't! I took your advice and ordered the stainless ones, 1 inch long, with the smaller 5/16" heads with 6 point heads. Thanks everyone for the help!
