Whats the bets Cam for 94 z28
Old Apr 25, 2003 | 06:18 PM
94Z28MAro's Avatar
What does everyone recommend for a cam for 94 z28 camaro and also my gas runs out so fast i just gave a tune up what should I do?
Old Apr 26, 2003 | 01:19 AM
96LT14u2Nv's Avatar
i wouldnt go any biger than a comp cams 306 cam on stock heads. the 305 cam is decent too. if your gas mileage sucks, u may want to check your fuel pump?
Old Apr 26, 2003 | 02:57 AM
ChuckZ28's Avatar
There is no best cam. Its all about what you want for your application. What all are you looking for? Do you want a little increase, big increase, street car, drag car, gas mileage, cam surge? It all should play a factor in what you want. Personally I have a pretty damn big cam for a street car that still has good drivability, passes emmissions, not too bad on cam surge or too too bad on gas mileage and It f*cking rips all on stock heads. Alot of this is due to great computer tunneing though and most people wont go this high due to close valve piston clearances but it fits me great and I love it. If your looking for a good street car with more power yet I would go with a cc305 or cc306.
Old Apr 26, 2003 | 05:42 PM
94Z28MAro's Avatar
I want my car to sound like really beefy at the idel? please help aLSO WHAT KIND OF HEADS SHOULD I GET???????? HELPPLEASE THANKS ANTHONY
Old Apr 26, 2003 | 09:12 PM
pgriffith's Avatar
You need to do some more research. And be more specific. We have no idea what cam would be best for you because we need to know your plans with the motor. Is it NA, Nitrous? Turbo? Supercharged? Be more specific do some research and then repost your question.
Old Apr 26, 2003 | 11:30 PM
94Z28MAro's Avatar
Im planning on putting heads and a supercharger. i want a cam that will make it sound really choppy. but as of what I have done to my 94 z28 is hooker long tube cermic coated headers, Y pipe , throttle body, MAF, 4.10 gears, K&N cold air, pullies. So I want a cam for this and that will work when i get my cam if not its cool. I just want a cam now that will sound choppy. My car http://www.bigdickmafia.com/anthony1.JPG
thanks Anthony
Old Apr 27, 2003 | 12:47 AM
Dr.Mudge's Avatar
Livermore, California? If so you are pretty limited, no big cams, unless your going to swap at smog time. Plus if you are going blower, that is going to help decide what type of cam to look at, you are most absolutely going to need tuning, a blower on a stock engine by itself is already a high risk situation, with our without Californias crappy gas.
Old Apr 27, 2003 | 02:04 AM
Dave88LX's Avatar
Search to get some ideas
Old Apr 27, 2003 | 04:29 AM
Twice The Fun's Avatar
you could always call a cam manufacturer and have them build you a custom cam to your specs.
Old Apr 27, 2003 | 09:15 AM
Smokn '94 Z's Avatar
Lightbulb
thanks Anthony
If you plan on a blower then you should get a custom blower grind. Something with a 114 or higher LSA. That would not give you your chop you are loooking for though. Also if you plan on doing all this to your stock bottom end be prepaired for a re-build. The pistions are very temermental....
Old Apr 27, 2003 | 10:15 PM
94Z28MAro's Avatar
I have forged pistons already and had my bottom re done what kind of cam should i get now for my y-pipe hooker long tube headers, flowmasters, throttle body 410 gears,MAF, and pullis i want soemthing choppy?cuz im not going ot get my other stuff my new manifold heads and blower till next yr.
Old Apr 27, 2003 | 10:47 PM
Dave88LX's Avatar
Huh?
Old Apr 27, 2003 | 10:51 PM
pgriffith's Avatar
only problem is a blower cam and a NA performance cam are totally different. you could get a blower cam now and sacrafice HP now or you could get a NA performance cam now and sacrafice HP later when you get the blower. It just doesnt work.
For NA performance I would get the CC305 or CC306. CC305 if you want any chance to pass emissions and 306 if you want the most power.
With a blower cam you want something with less valve overlap. To get less overlap you might want less duration with a higher Lobe sep angle. And you waant to favor the exhaust a lot more. So the designs are totally different. A blower cam will not work for you now.
Old Apr 28, 2003 | 04:28 PM
jeff1586's Avatar
call up combination motorsports they will set you up with the head/cam package perfect for your needs.
rideordie
Nov 5, 2019 04:52 PM
Noenav
Mar 1, 2019 07:38 AM
Killer94z
Jan 13, 2015 12:06 PM
NewsBot
Dec 21, 2014 06:55 PM
chuyz28
Nov 25, 2014 11:14 PM
