Whats the best way to store LT1 heads?
Old May 31, 2006 | 04:49 PM
wrd1972's Avatar
I got my spare aluminum LT1 heads in today. They will not get ported any time soon so they will be in storage.
What is the best way to store these so they don't warp or get damaged?
I want to put them in my attic which will get hot in the summer time.
Old May 31, 2006 | 05:10 PM
ulakovic22's Avatar
Re: Whats the best way to store LT1 heads?
Mine are just covered by a towel in my garage sitting on top of an old dryer in the corner. I don't think you have to do anything special. Since you are having them ported I wouldn't even worry about cleaning them up since they will get tanked by the porter before he begins.
Old May 31, 2006 | 06:20 PM
LameRandomName's Avatar
Well, I wouldn't expect them to become warped from the sort of temps you see in your attic.
If it was me, I would use some spare lumber to build a convenient device to hold them. I'll leave the design up to you.
Beyond that, I like plastic bags and dirty oil. Why DIRTY oil?
Because dirty oil sticks to metal surfaces quite well where clean oil won't. I suspect it has something to do with surface tension and the ability of the dirt to provide a sort of a structure for the oil. Used engine oil works well.
Some folks might object to that based on acids in the oil. Myself, I've been using this trick so long that when I began, Jim Morrison was still alive. I have never seen any problems from it, probably because we're talking about trace amounts of very weak acids. Think about it... Ever burned your hand with used oil? Other than from heat I mean...
If you really hate the idea, then used tranny fluid will work too. Or if you insist on clean oil, ordinary gear oil will work.
All these ideas clean up fairly easily with various methods, such as hosing them down with brake cleaner.
For the bags, you can get nice big ziplocks at Lowes or Home Depot. You can also use ordinary trash bags. All you really want to do is keep the insects from making a home in your heads. Summit and Jegs even sell bags MEANT for engine and part storage.
Coat the heads, making sure you get all the nooks & crannies so that you protect them from oxidation. Put them in the bags and either zip or tape them up. Then place them in the wooden device you threw together to keep them from just banging around and you're good.
Old May 31, 2006 | 06:35 PM
396D1SS's Avatar
i just wd40-ed mine and threw them in a garbage bag used them about 6 months later and they had no rust
Old May 31, 2006 | 06:41 PM
Spitfire557's Avatar
Well I sure hope the ALUMINUM heads didn't rust.
Old May 31, 2006 | 06:46 PM
user 647483's Avatar
Wow, I hadn't though much about oxidation.
I typically clean spare parts and put them on the shelf in the garage /shrug
Old May 31, 2006 | 08:19 PM
Josh'95Z28conv's Avatar
If they're going to be worked on, just throw them in the corner and let them collect dust. Its not going to matter. Otherwise Id spray them with wd40 and put them in a trash bag if you're really worried about it.
Old May 31, 2006 | 10:44 PM
Jameslt1TA's Avatar
Just put em up in the attic where they wont fall or get damaged. If your going to have them ported it wont matter how you store them(oil, bags...ect.)
Old Jun 1, 2006 | 12:56 AM
1racerdude's Avatar
Store them on the engine.
Old Jun 1, 2006 | 06:57 AM
wrd1972's Avatar
Does this mean i will now have a 32 valve ghetto LT5, Brilliant.
In the bags and in the attic they go.
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Dec 1, 2014 08:08 AM
