whats the best way to improve the top-end?
Old Apr 27, 2005 | 08:59 PM
jasons93z's Avatar
I want my top-end to pull like my bottem-end does. Whats the best way besides a cam to do this?
Old Apr 27, 2005 | 09:12 PM
1racerdude's Avatar
Re: whats the best way to improve the top-end?
Ya can't have both.
Cam will move your torque up in the RPM band.
There is only about 3-3500RPM band that is making the power. You can move this up or down.
What I do is build the requested engine with the Peak power at 65-7000 for a street engine and use the gear to get it back down low.
Make your engine as powerful and with the most torque ya can in the upper range and use the gears to get it outt'a the hole.
Old Apr 27, 2005 | 09:39 PM
rskrause's Avatar
Moderator
Originally Posted by 1racerdude
Ya can't have both.
Absotively, or is that posilutely?
Rich
Old Apr 27, 2005 | 09:54 PM
1racerdude's Avatar
Rich
Close.
Blower's and NO2 don't count.
Old Apr 27, 2005 | 10:00 PM
cat1055man's Avatar
There are cams that have minimal effect on low end perf. that will move the power band up and make it pull hard to 6000rpm. But if a cam change is not a path you want to take you can install a supercharger kit. The stock cam will give you low end torque and the supercharger boost will deliver tons of power in the upper rpm range. Get a kit with intercooler for best performance and engine protection against high inlet temps. and detonation issues.
Old Apr 28, 2005 | 12:15 AM
RedLT4Mike's Avatar
a dry nitrous kit with a small shot and a window switch set to 4k-6k
I know n20 doesn't count, but you leave no choice!
Old Apr 28, 2005 | 12:24 AM
1racerdude's Avatar
Build a 706CI BB and ya got the best of both world's. Doesn't matter much how it's cammed and ya don't need a blower or nitros.
Old Apr 28, 2005 | 08:30 AM
WS Sick's Avatar
Or you could just race to 60 all the time.
Old Apr 28, 2005 | 09:21 AM
Blownbird355's Avatar
Boob job!!
Old Apr 29, 2005 | 01:20 PM
jasons93z's Avatar
im back with the stock 1.5 rockers but still have the stiffer lt4 springs. Im thinking that a cam swap will be best. What is the cam that would suit me best with the lt4 springs and 1.5 rockers?
NewsBot
Sep 14, 2015 08:50 AM
CARiD
Sep 7, 2015 08:21 AM
Bails098
Aug 17, 2015 05:15 PM
karpetcm
Aug 14, 2015 03:02 PM
Boss002
Jul 9, 2015 03:33 PM
