whats the best way to clean the lt1 engine??
Old Apr 24, 2011 | 03:42 PM
Carlos8's Avatar
Question whats the best way to clean the lt1 engine??
hi i want to clean my engine and i would like to know whats the best way to do it???
Old Apr 24, 2011 | 03:58 PM
moparman's Avatar
Re: whats the best way to clean the lt1 engine??
There's a thread in Show and Shine about this.
Old Apr 24, 2011 | 07:38 PM
DAVE00's Avatar
Internal - Seafoam
External - Simple Green and elbow grease
Old Apr 24, 2011 | 09:41 PM
30th97z's Avatar
A hand held steam cleaner! Make sure that you cover the opti spark with a rag so that you don't get it wet!!!!!! Good luck.
Old Apr 25, 2011 | 12:42 PM
6SpdLT1Z's Avatar
I don't clean mine much for fear of accidentally getting the opti wet. But when I do... I put a yellow trashbag over the opti then use a hose and a spray bottle of diluted simple green.
Old Apr 26, 2011 | 02:19 PM
SweetZRag's Avatar
Externally, I use Gunk engine cleaner. Just spray it down, let it sit for 15 minutes, and hose it off. Don't worry about getting the Opti wet. It sees more water driving in a rain storm. It won't hurt it.
My Blazer has 360,000 miles and the Gunk does such a good job of cleaning grease and dirt that my block is actually rusting because it so clean and dry.
Old May 5, 2011 | 07:42 PM
white97z28's Avatar
I washed mine last year with just a garden hose and some degreaser and all of a sudden it ran like crap... We figured it out though it was my TPS went bad. Shifting,rpm and idle was all messed up.. Will not do that again.
Old May 5, 2011 | 09:14 PM
zobesZ28's Avatar
sprayed mine with acid degreaser and then watched the detail kid spray it down with the power washer......all is well
Old May 5, 2011 | 09:50 PM
stopthatman's Avatar
you should cover the alternator too, it could get trashed if stuff gets inside it
Old May 6, 2011 | 02:13 AM
Fatdog2's Avatar
Don't do it.if you have dust,use a brush.My02.Leave the engine alone.
Old May 6, 2011 | 08:38 PM
1995sixspeedz28's Avatar
yeah - I agree w/that at least compared w/hosing it down...
I use very little fluid - bit of water/simple green on a rag to wipe off... maybe a little lucas detailing spray on the hoses etc... not good to go in there w/alot of water let alone a hose imho
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
