Whats the best header bolts/gaskets?
Old Nov 23, 2005 | 10:17 PM
speed_demon24's Avatar
I currently have regular felpro D header gaskets and stage 8 locking header bolts, but I all of my primary's are leaking. I want to ditch the stage 8's, I hate them, and they are a PITA to re-tighten, and they really dont even work. And are the regular felpro D gaskets the best?
Old Nov 23, 2005 | 11:17 PM
3gc's Avatar
3gc
Re: Whats the best header bolts/gaskets?
Your gonna get a bunch of people saying a bunch of different variations work. Alot of things work for some people, but yet not for others. That being said. I've had success with some good Mr. Gasket header gaskets and Stage 8s on my old camaro. This time I went with mr gasket header gaskets and the Breslin, split lock bolts and haven't had to retighten it since the install. The Breslins were much easier then Stage 8s to install and work as well if not better.
simple's Avatar
felpro 1406 and ARP stainless bolts (is what i recommend) never had not a one issue with them in over 20,000 miles
use the search button, there was a couple page thread about a month ago on this same topic
Old Nov 24, 2005 | 12:36 AM
JKDZ28's Avatar
Felpro seems like a top choice
Personally I like my Stage 8 header bolts, they work great for ME.
Old Nov 24, 2005 | 12:52 AM
UtOhCop's Avatar
Mr. Gasket copper's worked great on my old LT1 SS
Old Nov 24, 2005 | 05:27 AM
nfa's Avatar
nfa
Im using GM multilayer steel gaskets along with 1" 6 pt ARP bolts. I checked the tightness after a couple of heat cycles and only had to re-tighten them once - no leaks!
Old Nov 24, 2005 | 10:29 AM
toegead93's Avatar
I used Felpro gaskets and never had a problem even though one bolt came out it was still air tight. I now use Split-Lock bolts...they are the bomb A liitle pricey, but I never have to worry about them coming loose and they are easy to get off...no messing with the stage 8 locking clips.
Old Nov 24, 2005 | 11:24 AM
DugRat's Avatar
Felpro 1406 and ARP 1" stainless bolts, checked them 2 or 3 times over the first 2 weeks and have run over 50,000 miles with no problems.
Old Nov 24, 2005 | 11:39 AM
quickSS's Avatar
whelp, you know, if you ever do end up with a leak or two, no matter what your favorite gasket or bolt is, try adding 2 or 3 ARP header studs in the bolt holes that are easy to wrench on. Then you can torque that stud nut down until you see stars. And the gasket will be good and squished and the bolts near the stud can be wrenched sorta tight and they shouldn't back out because the gasket shrunk. Header studs are the best invention since the small block chevy engine.
Karl Ellwein
Old Nov 24, 2005 | 12:07 PM
BlackDog's Avatar
I think the big issue with header leaks is the header flange it self. I had leaks as well.
I tried 3 different types of gaskets from metal to Felpro and Mr. Gasket. They all leaked at some point.
When I removed the headers, I took a straight edge across the whole flange. Guess what? They weren't straight. I took my belt sander to the flanges and squared them out. I don't have anymore leaks now.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
