whats the best damper to get on my new motor
hey guys im in the market for a new harmonic balancer or a fluid damper, i dont know much about these and exactly what they do, which one should i get, what would be best? if there is anything that you need to know please just ask me
I spent alot of time researching this least week and it seems there are two heated factions ATI and Fluidampr. I read fluidampr went under at least one time. I've heard ATI is a good company overall, although I've also seen alot of 1000hp+ pulling trucks swear by Fluidampr. I was actually going to post a similar thread so see if there was any additional information since most of what I found was opinion.
I'm guessing I'd use whoever my engine builder recommended, that way if it came apart it would be on him.
-Dustin-
-Dustin-
The ATI damper will come with the damper and a new hub. A new ATI damper would not work with the stock hub. I don't have the part numbers handy but when I ordered mine if I remember correctly there are 2 to choose from, 1 is stock diameter, and the other is slightly smaller (underdriven) and requires a shorter belt - that is what I ended up with.
I went with the Fluidampr. I think its funny how ATI actually advertises that the fluid dampr works better under 7k rpms. (Look at ATI's PDF file and see the comparison graph) These motors don't really rev over 6k. Also the fluidampr doesn't have to be 'tuned'.
ohh ok because i was gonnna buy one used from someone here and he has 2 and said one was for an internally balanced motor and one was for an externally balanced motor, (one has a weight on it and one doesent)
You state you have an internally balanced LT1 engine. If that is the case, you need a neutral balance flywheel (or flexplate) and a neutrally balanced damper (it is not a balancer, just a damper). If you had an externally balanced LT1 engine, you would need a flywheel (or flexplate) with a balance weight on it, and a neutrally balanced damper (it is not a balancer, just a damper). Does not matter. You want a neutrally balanced damper.
If you had an externally balanced Gen 1 SBC, you would use a damper/BALANCER with a weight on it. But you have an LT1.
carguyshu
Jan 22, 2017 11:19 AM
alex5366
Mar 27, 2015 03:30 PM
NewsBot
Dec 28, 2014 06:20 PM
