whats the best combo for 400rwhp
Old 12-23-2003, 02:10 PM
TrouserSnake's Avatar
Im getting a 355 bare Block.
I want 400 rwhp N/A.
My goal Is 130 traps with Nitrous Safe
whats some Proven Combo's you guys have seen.
Im Thinking
Forged crank
Forged Rods
Foged Pistons
Comp Cams custom Grind
Some Used ported Lt4's
1.6 RR's
Meziure elect. pump
Hooker Lt's with True Duals
58mm tb
150 wet Shot should get me in the high 120's
Can this be acomplised for under 5000
TrouserSnake is offline
Old 12-23-2003, 03:05 PM
magius231's Avatar
you could probably do it with good heads and a good custom cam with a built shortblock to handle the large shot of nitrous (383 maybe?)...for $5000? seriously doubt it. The build of the shortblock alone is going to be in the neighborhood of $3000+, the heads will run you over $1000, and the cam is another $250-$400 depending on what cam you get (not to mention miscellaneous crap which you can count on at least another $1000, like timing chain, new lifters, rockers, bolts, gaskets, tuning, etc). If you can get everything used you might be able to scrape by $5000, but everything will be...used.
magius231 is offline
Flint78
06-21-2015 01:28 PM
05-21-2015 01:04 PM
SpeedJunkee
04-23-2015 09:51 AM
canbaufo
Parts Wanted
02-21-2015 11:51 PM
vhgjk123
08-01-2002 10:52 AM
Quick Reply: whats the best combo for 400rwhp
