whats the best combo for 400rwhp
Old Dec 23, 2003 | 02:10 PM
TrouserSnake's Avatar
Im getting a 355 bare Block.
I want 400 rwhp N/A.
My goal Is 130 traps with Nitrous Safe
whats some Proven Combo's you guys have seen.
Im Thinking
Forged crank
Forged Rods
Foged Pistons
Comp Cams custom Grind
Some Used ported Lt4's
1.6 RR's
Meziure elect. pump
Hooker Lt's with True Duals
58mm tb
150 wet Shot should get me in the high 120's
Can this be acomplised for under 5000
Old Dec 23, 2003 | 03:05 PM
magius231's Avatar
you could probably do it with good heads and a good custom cam with a built shortblock to handle the large shot of nitrous (383 maybe?)...for $5000? seriously doubt it. The build of the shortblock alone is going to be in the neighborhood of $3000+, the heads will run you over $1000, and the cam is another $250-$400 depending on what cam you get (not to mention miscellaneous crap which you can count on at least another $1000, like timing chain, new lifters, rockers, bolts, gaskets, tuning, etc). If you can get everything used you might be able to scrape by $5000, but everything will be...used.
Flint78
Jun 21, 2015 01:28 PM
May 21, 2015 01:04 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
vhgjk123
Aug 1, 2002 10:52 AM
