What is wrong with my car
Old Mar 22, 2005 | 11:27 AM
97ramairta's Avatar
well, my car is running like $hit right now. when ever i get on it stutters and sounds like it is back firing. and sometime i will just be going along about 30 mph and out of no where it will get a power surge. then also when it is acting up really bad, the SES light will start flashing. i have checked the opti and my plugs and wires. they are all fine. does anybody have a clue or any suggestions. any help would be greatly appreciated. thanks
BTW my car is a 97 Ram Air TA
Old Mar 22, 2005 | 11:46 AM
IXLR894Z28's Avatar
Re: What is wrong with my car
I'm thinking O2 sensors may be going causing it to run rich, and setting off the dreaded SES light.
Old Mar 23, 2005 | 06:02 AM
slopokrodrigez's Avatar
Scan it and stop wasting time guessing.
Old Mar 23, 2005 | 11:14 AM
Z28SORR's Avatar
This kind of od ball stuff usually ends up being emitions related.
Old Mar 23, 2005 | 02:00 PM
m0nk's Avatar
I had a problem like this once and it was my TPS sensor, try unplugging it and see if you still get the problem. If not then thats what it is, 2 minute install. If the problem still occurs you know your TPS is still good
Old Mar 23, 2005 | 02:20 PM
moparman's Avatar
Do what he said. Save time and aggravation.
Old Mar 23, 2005 | 03:52 PM
m0nk's Avatar
If im reading it correctly the SES code only flashes on and off when the problem occurs, aka while driving. I got this assumption because it happened to me, and everytime I scanned it nothing came up.
Old Apr 20, 2005 | 08:26 AM
Compstall's Avatar
Come on down to my house I have an AutoXray scanner you can borrow.
Old Apr 20, 2005 | 09:32 AM
1-bad-z28's Avatar
wether the light is still on does not matter. The trouble code is stored in the memory and it can be pulled anytime.
ModdedNerd
Dec 18, 2014 10:52 PM
brentbrowning01
Dec 16, 2014 06:35 AM
USAirman93
Nov 24, 2014 03:37 PM
DrMilhouse
Oct 2, 2002 05:03 PM
JoeD316
Aug 16, 2002 09:12 AM
