what is wrong with my bone stock dyno???
Old Feb 4, 2005 | 10:13 AM
grannycar's Avatar
http://www.corral.net/photopost/show...at=6246&page=1
could it be that i was running cheap 87 oct. gas..i have a miss too.. at wot, when shifting into second..well when the trans shifts..the car bucks and stops and the rpm stays the same..also when on the highway in overdrive at low rpms' i noticed the rpms were going up and down.."missin"
Old Feb 4, 2005 | 10:17 AM
kcshaner's Avatar
Re: what is wrong with my bone stock dyno???
The high idle could be a vaccum line or fouled sensor...just my $.02
Old Feb 4, 2005 | 10:35 AM
ShawnMacAnanny's Avatar
Wow that looks like the seismographs from Tremors...
Old Feb 4, 2005 | 11:24 AM
Zigroid's Avatar
you make more power than I do with the mods in my sig... I think the question is whats wrong with my car lol.
http://home.comcast.net/~zigroid/firebirddyno2.JPG
Old Feb 4, 2005 | 11:34 AM
TransAm2k4's Avatar
GrannyCar i think it might be something electrical because of the Bouncy band or maybe the car wasn't well straped to the dyno. But the power isn't that bad for a stock LT1 A4. I got a friend with a 94 z28 (100k miles) made 248 rwhp and i dont remember the tq but that was with a CAI.
Zigroid it looks as if you are running rich, but i notice that the tq on the 2nd pull was defenitly wrong 220 lbs-ft.
Old Feb 4, 2005 | 11:44 AM
MTL_Z28's Avatar
Also it appears that you only revved to about 4200 RPM on that pull. I forgot where stock power peak is but I'm pretty sure it's above that.
Old Feb 4, 2005 | 12:02 PM
grannycar's Avatar
well the idle isnt high.. its just becuase its an auto and they needed it to stay in 3rd gear so it wont down shift...
Old Feb 4, 2005 | 12:12 PM
stereomandan's Avatar
Looks correct, except for how bad the curves are.
244 rwhp 285 rwtq is right on for a stock A4.
Dan
Old Feb 4, 2005 | 12:29 PM
Fuels94TA's Avatar
Dan
I agree with with you. gannycar I belive you can get more if those crazy lines didnt show. That a sign of a week or bad electrical problem, also run high grade gas don't be cheap when it come to the car.
Old Feb 4, 2005 | 01:10 PM
BIG SHAFE's Avatar
You know that the LT1 requires 91/92 octane? You shouldn't be running that low octane, it will cause the engine to run rich/lean back and forth, trust me I know.
Old Feb 4, 2005 | 04:39 PM
Guest47904's Avatar
Guest
Unless you have a friend with a free dyno, why would spend the money to dyno if you know you have a problem?????? When you get a number...like you did, what does that mean?? Will you be able to say, "If I'm this good now, just wait till I get it fixed, I'll kick your A$$"?????
How do you know the problem isn't such that when kicked up to 5 or 6 grand wouldn't blow the engine????????? Seen plenty of blown head gaskets causing misfires and that situation could easily hydro lock. OUCH.
Bill Engvall said it best
Here's your sign
Old Feb 4, 2005 | 07:05 PM
grannycar's Avatar
first off speedy gonzales, i didnt know i had a problem nor would anything cuase a problem..second my head gaskets were just done about 2000 miles ago and the heads were machined down....
Old Feb 5, 2005 | 03:07 PM
grannycar's Avatar
what electrical things could be going bad? spark plugs/wires, opti? coil? are they hard to install?
Old Feb 5, 2005 | 03:37 PM
BIG SHAFE's Avatar
Exclamation Re: what is wrong with my bone stock dyno???
YO! You are running the wrong octane, running the wrong octane will give you missing, un-normal idling, etc. You had your heads machined down, thus increasing your compression ratio, which means you really need a higher octane. Get some new gas!!!
Old Feb 5, 2005 | 06:22 PM
Fuels94TA's Avatar
Yap, if the wire gets a hot spot it will crack the installation which cause the wire to ground out the car to miss, that will also go for a bad or loose spark plug. I wouldnt worry about the opti just yet leave the worst for last.
