What would I make
What would I make
Working with a 95 z28. I got a lot of the parts picked out...CC 467 cam (.230/.236 113 LSA), CC 1.6 RAs, 5/16 CC magnum push rods, new lifters, new SR valves (2.020/1.600), new CC valve springs, TFS heads (195/75cc) Edlebrock LT4 intake, 58 mm TB, SLP CAI, Hooker comp headers and ORY to dual exhaust, 2800 stall, 3.73 gears( I want to do 4.10, but Im worried about the stock rearend). Off of that, what do you guys think I will be putting to the ground after a good tune? Also, if anyone has suggestions on alternative stuff I should look into, please let me know.
Re: What would I make
3.73 gears with an automatic retains the driveability while giving you a nice boost. 4.10 gears will raise the highway rpm significantly...maybe too high for comfortable cruising.
Do a bit more research on your cam selection, especially since comp cams literature seems to be a bit off when it comes to the LT1. ...
Good luck and welcome to the site....
Victor Lamb
Aug 26, 2017 02:52 PM
