What would help this?
Why does it seem when i first start my car and the temp. is around 160-180 it seems to run stronger. Then after it warms up more it seems to lose some power. The temp usually stays in the middle. Do you think this is just in my head or does the extra heat make it loose some power. Do you think a 160 stat will help this out?
