what would be easier??
Old Dec 25, 2006 | 10:46 PM
bitchin94's Avatar
So I am puting 3.73s in my car after that what should I do LTs and a Y pipe or 1.6 RR, LT4 KM, and LT4 springs. Which will give me the more horse power and which one is easiest to do??
Old Dec 25, 2006 | 11:04 PM
Kevin Blown 95 TA's Avatar
If I were you, I would do the valve springs and rocker arms first. Not sure if it would be a tie for hp, given your mods, but if you got original springs on a 94, they are shot anyway, so new ones will wake up your car, especially since you are doing a gear. Then maybe do a converter, then heads/headers/cam.
Old Dec 25, 2006 | 11:07 PM
fredmr39's Avatar
1.6 RR, KM, and springs are easier...but yield less hp (maybe ~10)
LTs and Y-pipe aren't necessarily hard - just time consuming....but very doable. Depending on your luck, certain things will slow you down.
Old Dec 25, 2006 | 11:10 PM
fredmr39's Avatar
I agree you could probably use some new springs anyway if they are original - I've just always liked making the motor breathe easier before anything else.
Old Dec 26, 2006 | 01:36 AM
seawolf06's Avatar
I'd do the exhaust first. You will see more gains from the RR that way when you do get to install them.
Old Dec 26, 2006 | 04:19 PM
2000GTP's Avatar
The best gains will come from the exhaust work but will be more difficult to do versus the rockers/springs swap which will be a easier but most likely not yield as high of gains.
Sep 18, 2015 03:46 PM
alliance12364
Sep 17, 2015 08:43 AM
Aug 24, 2015 06:41 AM
SpeedJunkee
Jun 6, 2015 04:27 PM
blkWidow
May 3, 2015 08:42 AM
