What would cause a rocker to come off the pr?
Old Aug 17, 2008 | 08:40 PM
BCdawg57's Avatar
I have a set of proform 1.6 roller rockers, magnum pr's, and cc hydraulic lifters. I adjusted the lash to what i thought was correct, and start the car. Car runs fine at idle, back it up a bit and pull it forward, shut it off. Try to start it again and the exhaust rr on cyl 1 was off the push rod. so i put it back on, and later today the rr on exhaust cyl 5 came off.
Whats the deal? Improper lash adjustment or are the locks backing off?
Old Aug 17, 2008 | 08:44 PM
wrd1972's Avatar
Are these self aligning rockers?
Old Aug 17, 2008 | 08:47 PM
BCdawg57's Avatar
oops, sorry.
Yes they are self aligning.
Old Aug 17, 2008 | 09:15 PM
maverickmk's Avatar
are your heads set up for SA rockers? there needs to be space for the sides of the rockers adjusting mechanism to align with on the end of the valve - for non SA rockers the retainer is almost flush with the top of the valve.
this is set up for non self-aligning rockers - if your setup looks like this than you need to get different rockers - also, Proform rockers aren't the best rockers in my opinion
Old Aug 17, 2008 | 09:33 PM
BCdawg57's Avatar
I dont know if you can tell from this pic but this should tell you. Im pretty sure they are set up for sa rockers.Name:  DSCF0122.jpg
I know proform arent the best rockers but they shouldnt be bouncing off the pushrod regardless. Could improper lash adjustment cause what i am describing?
Old Aug 17, 2008 | 11:11 PM
Green96Z's Avatar
That would be my guess. How much preload did you use? What rocker nuts are you using?
Old Aug 17, 2008 | 11:40 PM
Assuming the alignment tabs are not an issue, I would first suspect improper adjustment.
Old Aug 18, 2008 | 08:12 AM
BCdawg57's Avatar
I am going to readjust them today using the running method.
My confindence in these rockers is very low right now im afriad to drive the car with them on.
Old Aug 18, 2008 | 02:31 PM
BCdawg57's Avatar
i went out and adjusted them with the car running. It seems the locks keep backing off. The same rockers i had pop off are the ones i have to keep retightening. Anything i can do to fix this minus getting new locks?
Could this be another problem? like a lifter problem of something like that?
Old Aug 18, 2008 | 02:36 PM
BUBBA's Avatar
The ends of your stock rocker studs are probably not machined and not providing any bite for the locks. Suggest you switch to ARP studs which should elimininate that problem. JMHO
Old Aug 18, 2008 | 02:38 PM
BCdawg57's Avatar
bah. wouldnt it be easier to put loctite or something like that on there?
Old Aug 18, 2008 | 08:06 PM
hempkat94z28's Avatar
Come on man If it doesn't stay tight any longer than running then that Loctite won't help. Get some new studs and get it over with!
Old Aug 19, 2008 | 03:56 PM
mkent's Avatar
I've had rockers come off when a valve spring broke, and I've had rockers come off when I adjusted the valve lash but forgot to tighten the polylock. My guess is you forgot to tighten the lock. If you had a rocker fly off, check your push rods. Mine bent when it happened to me.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
