What would cause having a Gas Gauge needle stuck at full?
Old Nov 29, 2004 | 05:19 PM
crAzy95z28's Avatar
i took out the assembly, tried messing with all the wiring, and that didnt work!!!
any other clues?
Old Nov 29, 2004 | 05:20 PM
TobyZ28's Avatar
Re: What would cause having a Gas Gauge needle stuck at full?
Is your gas tank full....?
Old Nov 29, 2004 | 05:41 PM
My94T/A's Avatar
My 94 has the same problem. Took it to the dealership and they said the Fuel sending unit is broken so I picked one up from this site. U just have to look out for Parts for sale and you might score a deal.
Old Nov 29, 2004 | 05:56 PM
crAzy95z28's Avatar
pics of the sending unit?
Old Nov 29, 2004 | 08:41 PM
My94T/A's Avatar
Sorry couldn't get a pic of the sending unit....check out this site
https://www.rockauto.com/applet3.html if u email them...they might sent you pic....
Old Nov 29, 2004 | 08:49 PM
crAzy95z28's Avatar
300$$$$$$$$$$$$$
Old Nov 29, 2004 | 09:49 PM
Birdman7389's Avatar
Time to call Jason Cromer.....
Old Nov 30, 2004 | 10:51 AM
93ZM6Tally's Avatar
Don't have pic's of the sending unit but it's the complete assembly that your fuel pump, (inside the tank), mounts to, including the lines that you see coming out of the top of the fuel tank. FWIW I picked up a complete unit including fuel pump for $50.00 at a local salvage yard. I changed the fuel pump, but the wiring, level sensor, float and everything else are working fine.
And BTW and open ground connection will cause your fuel guage to read Full, usually pegged past the "Full" mark. Check your connectors which are underneath the car near the rear axle on the drivers side, basically up in the "hump" that your rear seat back sits on.
Old Nov 30, 2004 | 11:00 AM
Tom Piper's Avatar
Last summer, there was some high-sulfur gas (I think it was Shell) got out to some gas stations that caused many sending units to "lock up."
Shell had to repair several for customers.
Tom Piper
Old Nov 30, 2004 | 11:30 AM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
yep its just a bad sensor, my mothers dodge caravan gets stuck at full for like 1/2 tank then it will drop right down to 1/2 instead of Full all the time, Very weird
Old Nov 30, 2004 | 01:44 PM
crAzy95z28's Avatar
i might check the wires, cause it stays pegged at full, and everynow and then, it starts to drop to a bit above the half mark!!!
Old Nov 30, 2004 | 04:07 PM
You can check the sensor by measuring the resistance as it moves from empty to full. Shoebox (as usual) has the resistance values on his Tech Pages website.
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
