what would cause the counter weights to rub the block?
Old Nov 5, 2006 | 08:36 PM
Robs97Z28's Avatar
I replaced the timing chain a few months ago. did I reinstall the crank spocket too far?
The crank is rubbing on the block. it feels very tight and is hard to move to check the end play.
any ideas would help, rob
Old Nov 5, 2006 | 10:29 PM
ak95ta's Avatar
As far as i know, you cant install the crank sproket too far. What is the end play? Can you visually see the counter weights rubbing the block?
Old Nov 5, 2006 | 10:49 PM
Rubbing, where? Need more details.
Old Nov 5, 2006 | 10:54 PM
Robs97Z28's Avatar
Yes, there is a very loud grinding noise when the engine is hot. you can see where the counter weights are rubbing. When it is first started, there isn't any noise. oil pressure is fine. I took everything apart looking for the grinding noise. I first thought it was the new oil pump that I installed. I thought that hte oil pump drive shaft was too long. I notice the crank seemed off set. it is being pushed to the trans.
Old Nov 5, 2006 | 10:58 PM
Robs97Z28's Avatar
between the counter weights, the block and the main caps. it seems like the thrust surface of the trust main bearing failed. I'm not sure. I only removed the pan and oil pump, so far.
Old Nov 5, 2006 | 11:00 PM
If you beat the hub on with hammer and block of wood like many people like to suggest, you could have damaged the thrust bearing.
Old Nov 5, 2006 | 11:03 PM
Robs97Z28's Avatar
I used damper press and puller. It is a high mileage motor with 184,000.
Old Nov 5, 2006 | 11:06 PM
Just throwing out possibilities, since you said the timing chain work was recent. I guess you better check out that thrust bearing anyway.
Old Nov 5, 2006 | 11:09 PM
Robs97Z28's Avatar
Yea I know. That is why I am here, trying to get Ideas. Trying to figure out why this happened.
Old Nov 5, 2006 | 11:51 PM
SStrokerAce's Avatar
If the crank is moving way back in the block to rub a counterweight your thrust bearing is GONE!
Bret
brothaslide
Jan 9, 2016 12:11 PM
4586
Jul 31, 2015 06:03 PM
jackpawt883
Jul 31, 2015 08:15 AM
Jlo
Jul 29, 2015 03:52 PM
alphaauto
Jul 26, 2015 04:40 PM
