What in the world happened here....
Old May 25, 2005 | 11:07 PM
LT1-Z's Avatar
Well i decided to give my engine a little clean up after just purchasing it. Well i sprayed it down with the hose, and put some Sea Foam in it to help clean the inside of the engine. well when i was done i tried starting it and it wouldn't turn over after 5 seconds (usually takes 1-2) so i stop and tried it again. took me 5-6 times before it started but then it started miss firing. I know i got water in there somewhere and it just needed to dry out, but what got wet that made it do that? All i know is it was arcing to the block or frame. and i couldn't get above 2000 RPM unless i gunned it and then it would miss fire like all hell broke lose. What'd i do to make it do that? or what got wet besides the spark plug wires? (that would make it not go above 2000 RPM)
Old May 25, 2005 | 11:18 PM
lt11997's Avatar
Re: What in the world happened here....
You might of just took out your oti-spark.
Old May 25, 2005 | 11:19 PM
blaze309's Avatar
Well you made one big mistake.( Ok so it's not the biggest mistake you could make)
Your not supposed to wash the engine bay on a lt1. Your car is probably miss firing because you got the opti wet, it may be ok once it dries out or you may have to replace it. Some of the other board members can give you more info on this.
Also with the arcing (not sure if the opti getting wet could cause it to arc) but if the arcing is coming from one of your plug wires then you'll need to replace that since that will also cause a miss-fire.
Old May 25, 2005 | 11:29 PM
resurrectedz28's Avatar
Eh, everyone messes up at some point, let it dry out and see what happens, could be your opti....
Old May 26, 2005 | 09:35 PM
LT1-Z's Avatar
Well it runs fine now. About 45 minutes later it all of a sudden decided to work right and quit miss firing. It would idle really rough and shake the car pretty bad, but then all of a sudden it quit and stopped shaking and hasn't miss fired yet again (knock on wood). So do you still think i should replace the wires/plugs?
Old May 26, 2005 | 09:46 PM
cwaldt's Avatar
Hopefully you'll be fine. Let it dry out some more and see if it does it again. If it doesn't consider yourself lucky. Since its a new purchase it wouldn't hurt to change the plugs and wires unless you know someone done it recently before you bought it. Some might disagree, but I changed out everything I could after I bought mine just to be sure.
Old May 26, 2005 | 09:49 PM
1996camarors's Avatar
Make a couple of runs down your street and let us know how she is feeling
Old May 26, 2005 | 10:10 PM
lt11997's Avatar
You are one lucky guy.
Old May 26, 2005 | 11:12 PM
LT1-Z's Avatar
Just test drove it again, seems just as normal as before i wetted it down. Although i noticed my RPM will shoot well past 6000 now...? it got up to about 5500 then shifted before, now it'll go to 6000 or more until i reach 60 then shift. (it shifted at 60 before too, just not at 6000 RPM)
Old May 26, 2005 | 11:16 PM
lookingforwheels's Avatar
I got my motor wet before and it started acting funny, then like yours it just stopped.
LT1-Z's Avatar
And just out of curiousity, what do you guys recommend for wires and plugs? I was thinking Accel 8.8mm or something...no?
Old May 26, 2005 | 11:35 PM
MeanGreen97Z's Avatar
IT is not the wires or plugs. Guarantee it is the optispark. That is the distributor on the motor and is vital not to get it wet!
Novo
Jun 14, 2016 02:58 AM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
