What wires could be grounding out?
Old Mar 19, 2004 | 03:09 PM
SLeeper94Z's Avatar
I keep blowing my fuse 6 fans/actr... what wires are associated with this fuse how can I trace this down? thanks
Old Mar 19, 2004 | 04:44 PM
I know the items it powers were listed in another of your threads. You can pull the fuse and either use a meter or test light on the load side to see if you have a short to ground. Then you can unplug/isolate the items the fuse powers to see if you can remove the short. If you don't have any experience/knowledge in tracking down these kinds of things, it's going to be hard to do.
Old Mar 19, 2004 | 04:47 PM
WS Sick's Avatar
Thats some good advise shoebox, just as he said if the components are accessable and yo have a short on the circuit, remove em one at a time and see if the short disapears, if the components dont remove it then youre wiring is hosed somewhere.
Old Mar 19, 2004 | 05:00 PM
SLeeper94Z's Avatar
O god I was out checking my wires, came back inside to get haynes manual .... came back one of the jack stands broke in half
shew .... i was just out there 5 mins ago!!! never seen a jackstand do that ... neways everytime I start it screeches right when the fuse blows , what would make this sound airpump is unplugged and everything , is it the fuse making that sound?
kinda off the topic,will autoxray scan for transmission codes?
does it give you readings of your 02's Etc?
Critter
Jul 7, 2015 08:33 PM
ad356
Apr 22, 2015 08:35 PM
blac94Z
Mar 20, 2015 09:58 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
kandied91z
Aug 6, 2002 01:18 AM
