what and where is the crank seal?
Old Mar 11, 2003 | 01:42 PM
96Z28man's Avatar
Someone checked my car's leak and said it was the crank seal.
What is the crank seal????
Old Mar 11, 2003 | 02:33 PM
GREGG 97Z's Avatar
It's the bottom seal on the timing cover that seals around the crank hub. The harmonic balancer mounts to the crank hub, which goes through the timing cover and bolts to the crank. Do you know if that seal was changed when you got the Hotcam installed?
Old Mar 11, 2003 | 03:25 PM
96Z28man's Avatar
Ya, I changed the seal. I hammered it in and I made sure I didn't bend the rubber lip, but I guess it did,there is oil splashing out pretty good. What should I use to install the new seal in order not to ruin it?
Old Mar 11, 2003 | 03:28 PM
LPEdave's Avatar
A piece of PVC the right size... I wrote a page here: http://www.go-fast.org/z28/crank_seal.html
Dave
HectorM52
Jul 30, 2017 11:46 AM
dylan1303
Aug 12, 2015 02:00 AM
jwade88
Jun 14, 2015 09:38 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
1LEThumper
Jul 14, 2003 12:45 PM
