What is THE valvespring to run?
Old Apr 23, 2004 | 08:59 AM
LTOne4Fun's Avatar
Anything good that fits in stock pocket? WOuld like a double, not for a huge cam, but healthy ramp rates and prolly 6500 rpm
Old Apr 23, 2004 | 09:12 AM
WS Sick's Avatar
If you buy a comp seat that fits over the guide, stock heads dont need macining for a 1.46 or 1.5 wide spring.
but as ar as using the stock seat, it is set up for a single spring , still making you have to change the seat (with at least a shim.)
Comp and crane both make a stock dia spring good to .550 lift.
Old Apr 23, 2004 | 09:17 AM
truedualws6's Avatar
Beehive ovate springs seem to be getting a lot of
press lately.
Comp Press Release
David Vizard Article
Some SS Impala folks have tried them on LT1s and the
spring fits in the stock pocket. There is still lots of talk
about the exact combination because you need special
retainers. LS1s have 8mm vs 11/32 valve stems and I
have not seen a post with everything dialed in.
I would like to see more comments from the f-body folks
regarding the Comp 26915 and 26918 springs.
Old Apr 23, 2004 | 02:53 PM
llafro's Avatar
I am running Comp 987 springs with a 230/236-112 cam. That was what Combination Motorsports and Lloyd Elliott recommended independently of one-another.
The springs required machining the heads, but since they were already getting ported and all, it was only slightly more.
BRAD
Old Apr 23, 2004 | 06:05 PM
Naegash's Avatar
I am going to be running Comp Cams 977 springs with my XE 242/248 in my new stroker motor. These were reccommended to me by Phil at Advanced Induction.
Old Apr 23, 2004 | 09:53 PM
WS Sick's Avatar
BRAD
What machining was required?
HectorM52
Jul 30, 2017 11:46 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
