What valve springs do I need for 1.6 rockers?
Old Oct 22, 2017 | 01:28 PM
Slow1 trans am's Avatar
What are you guys running for valve springs when you swap to 1.6 roller rockers. Mid price range. 1995 lt1 trans am. Stock cam heads
Old Oct 22, 2017 | 05:40 PM
Chimera96's Avatar
Re: What valve springs do I need for 1.6 rockers?
Crane 10308-1 spring kit is a good replacement spring for stock H/C car with 1:6 rr
replace the valve stem seals also when you do this. Felpro
Old Oct 23, 2017 | 02:24 PM
Thanks ! Appreciate The info
Old Oct 23, 2017 | 02:38 PM
For anyone looking I was also told these will work
Lunati 73925K5 dbl spring kit
Old Oct 23, 2017 | 02:48 PM
Chimera96's Avatar
Those are EXCELLANT springs, I have them on my 383....may be a bit much of a spring for stock cam though
Contact Lloyd Elliott about them. I bought mine from him as he is a dealer for Lunati. If he says they are good for stock cam use than absolutely go for it. His $ are as good as anyone else on them
If he advises something else, go with those. The Lunati kit comes with new valve stem seals also but if you get another spring from him he sells seals separate also.
Old Oct 23, 2017 | 05:46 PM
lt1-xjs's Avatar
Howards 98215 springs use the stock hardware, leave out the damper coil.
