What vacuum should I see at idle???
Old Jun 8, 2005 | 04:05 PM
hambone3441's Avatar
With a hotcam setup???
Old Jun 8, 2005 | 04:42 PM
Pasky's Avatar
Re: What vacuum should I see at idle???
Believe anything below 13 #'s is not normal.
Old Jun 8, 2005 | 07:19 PM
I am seeing 16.4 on my scanmaster. Sound normal???
Rob
Old Jun 8, 2005 | 08:03 PM
Pasky's Avatar
Definately normal, anything over 15 #'s is good.
Old Jun 8, 2005 | 08:06 PM
speed_demon24's Avatar
Is your map reading 16.4 or are you subtracting your MAP reading from the BAR?
Old Jun 8, 2005 | 08:08 PM
Pasky's Avatar
Oh, MAP reading? No idea. I thought you were using a vacuum gauge.
Old Jun 8, 2005 | 09:41 PM
Thats what it is reading......
bar is 30.9
Old Jun 8, 2005 | 10:40 PM
ibanez6rg's Avatar
That must be nice to have 16.4. I get around 11 with a 306.
Old Jun 9, 2005 | 01:01 AM
BigJustinZ28's Avatar
im getting between 48 and 60 on my hypertech scanner . bar is 104 (im at or below sea level ) . Is that normal ?
Old Jun 9, 2005 | 01:33 AM
Spinner's Avatar
Use a VACUUM GAUGE. Dont judge vacuum by pcm readings.
Old Jun 9, 2005 | 02:50 AM
97WS6SCharged's Avatar
My gauge reads 11-12, my PCM sees 14-15. Course my cam is a little bigger than yours.
Hey Rob, did you get the rocker studs retightened? Hope you gave the machine shop a good thrashing over that.
Old Jun 9, 2005 | 04:31 AM
Yeah got them readjusted with new pushrods and all. Gave the machine shop a good piece of my mind also. So thats the reason I am asking about the readings on the scanmaster, wanted to know if sounds about right since I had to adjust the valves again. Chris thanks for all your help at G9 and all dont know where I would of been without the assistance.
Rob
Old Jul 8, 2005 | 01:40 PM
im gettin 8.5 inches and its running like crap lol
Old Jul 8, 2005 | 04:29 PM
Why not? Simple math.... BAR - MAP = vacuum.
Explain the error.
And... for all the people who used "#".... vacuum is either inches of mercury ("Hg), kilopascals (kPa) or psi... never "#".
Nayr
Mar 3, 2023 08:34 PM
KYWes
Jun 14, 2022 06:52 AM
Double aught
Oct 2, 2015 11:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
tdigger9899
Sep 7, 2015 10:56 AM
