what to use to push caliper piston in when changing pads
Old Apr 13, 2003 | 04:35 PM
96SS#724's Avatar
I'm about to change my rear breaks on my car. I know it is real easy I just haven't done it before.
What tool/clamp should I get to push the piston in when I am changing the pads?
Also is there anything else that I need to get besides new pads, rotors, and whatever I'll use to press in the piston?
Old Apr 13, 2003 | 04:42 PM
Rodrigues's Avatar
Youll need spindle grease and a C clamp (channel vise) to put the calipers back in.
Old Apr 13, 2003 | 04:53 PM
texasTA's Avatar
a 4" c-clamp. That is it
Old Apr 13, 2003 | 05:26 PM
notstock4long's Avatar
yep, I just put the old pad back on, and then compress the piston with a c-clamp. Just make sure you don't kink the piston, or go to fast, I think it is possible to burst a break line.
Old Apr 13, 2003 | 08:17 PM
$hawn's Avatar
On my rear calipers, I can push the piston back in with my fingers, maybe there something different on the 93 rear calipers and pistons, or something wrong with mine?
Old Apr 13, 2003 | 08:21 PM
sc93's Avatar
I dunno. On my 93, I had to use a C clamp on all 4 calipers
Old Apr 13, 2003 | 09:10 PM
Smokn '94 Z's Avatar
Thumbs up
C-Clamp. However my first time I used my powerfull hands...
Old Apr 13, 2003 | 09:12 PM
Blk94Z28LT1's Avatar
yeah a c-clamp or they make a little tool that works well too. I got one from pep-boys.
Old Apr 13, 2003 | 09:14 PM
James3219's Avatar
I did my brakes today and I used a huge set of plyers. These are adjustable from like 5 inches out to 1/2 inch. Took just under 2 hours from start to finish.
Old Apr 13, 2003 | 10:19 PM
JZ28Max's Avatar
might wanna take the brake cap off of the canister when you compress the pistons. it might make it easier to compress them.
Old Apr 13, 2003 | 10:24 PM
TonyJ's Avatar
I use the clamp when I can find it, but if you do it before you remove the rotor, you can just use a big screw driver behind the pad to pry it in.
Old Apr 14, 2003 | 12:15 AM
white97T/A's Avatar
I did rear pads this weekend and I was able to push the piston in with my hands -- just put the old pad on there and push steadily with your thumbs
carguy0119
Apr 11, 2016 11:11 PM
Dmonty
Jun 2, 2015 11:19 PM
Z-rated97
Mar 29, 2015 11:17 PM
NewsBot
Jan 21, 2015 06:10 PM
Redbird
Sep 14, 2002 09:18 AM
