what is this under my valve cover?
Old Jul 22, 2005 | 03:35 PM
phinger23's Avatar
it looks like chunky cheese mixture....yellowish shemegma color caked inside the valve cover...
what is it? i took pics, but no way to get them off the camera until later tonight
Old Jul 22, 2005 | 03:36 PM
Kain's Avatar
Re: what the hell is this under my valve cover?
Assembly lube. I had that junk all under my valve covers when I put a cam in. No big deal.
Old Jul 22, 2005 | 03:45 PM
ZMAN Z28's Avatar
Is your car blowing any white smoke?
Z
Old Jul 22, 2005 | 03:51 PM
phinger23's Avatar
yea, white smoke.
is that what coolant and oil caked up looks like?
im taking it apart to replace the head gaskets already...just wanna know what the schmegma is
Old Jul 22, 2005 | 04:31 PM
Loadre's Avatar
It's where you're burning coolant and it's getting in the oil and condensating on the valve covers.
Old Jul 22, 2005 | 05:49 PM
ZMAN Z28's Avatar
Yep you more than likely have coolant/h2o in your oil. Don't run it like that. You will probably spin a bearing. Find out where it is coming from.
ZMAN
Old Jul 22, 2005 | 06:17 PM
phinger23's Avatar
ZMAN
its my head gasket, i know that.
how do i get this metal like tube off the back of the intake??
Old Jul 22, 2005 | 06:27 PM
84 monte SS's Avatar
If its to the point that its chunky, i wouldnt even waste my time with the headgaskets.
Old Jul 22, 2005 | 06:35 PM
phinger23's Avatar
why do you say that?
the car has been sitting for about 2 weeks now, and hasnt been driven regularly for about 6 weeks...the only thing i did was drive it up the street just to let it run for a few minutes.
im guessing it caked up somewhat on the valve cover from sitting. actually, on the heads themselves, nots not caked up, just oil and coolant mixed, and same under the intake as well.
Old Jul 22, 2005 | 08:05 PM
Loadre's Avatar
The metal tube is the EGR. Two bolts hold it onto the back of the intake.
Old Jul 22, 2005 | 10:01 PM
ZMAN Z28's Avatar
a boxed end wrench should be able to get your egr/tube off.
Z
Old Jul 22, 2005 | 11:20 PM
Could also be the results of excessive piston ring blowby, and a faulty PCV system. The blowby contains water vapor, and the PCV system helps pull it out of the crankcase. If you have excessive blowby, or if the PCV valve is plugged, the water's going to condense in the parts of the engine that cool off fastest, like the valve covers. Running the car for only a short period, without getting the engine up to full operating temperature only makes it worse. Letting "it run for a few minutes" is worse than not running it at all.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
