what type of optispark ?
Old Feb 10, 2009 | 08:07 PM
dallas63's Avatar
i have a 1996 camaro z28 it has 160,000 miles . i getting a tuneup and waterpump replaced . i had several replys saying it was ok to replace just the cap and rotor and others saying i should relace the optispark . i use my car just as an everyday driver . so , if i really have to replace the optispark what is the most economical one . thanks for all of your advice
Old Feb 10, 2009 | 08:19 PM
96 Z-Ragtop's Avatar
I put an MSD Billet on my new 355 and I have nothing but praise for this opti. Sunday I was cruising and the hose off the drivers side of the water pump let go, spraying coolant directly on the opti. Not so much as a stutter. Had to add a little over a gallon of coolant to top it off. Fixed the hose, car fired right up and still runs like a champ.
So IMHO MSD is the only way to go.
Old Feb 10, 2009 | 08:23 PM
deerslayinrenek's Avatar
I would just go with the GM opti.......i've read many more horror stories than positive stories about other brands.....good luck either way you choose
Old Feb 10, 2009 | 08:29 PM
Dave1980's Avatar
I say get factory gm model. I have had good luck with them. I just took mine apart for my LTCC coil conversion, and they put factory locktite on the screws. The actual optical sensor is a mitsubishi part within the opti.
Old Feb 10, 2009 | 09:08 PM
DAVE00's Avatar
Stick with the stocker GM opti (AC Delco) as it's about half the price of the MSD unit and IMO they are more reliable as the MSD's are prone to coming apart at higher RPMS and the cap screws can come out at MSD doesn't locktite em' in. Do some searches and you'll find tons of info.
Old Feb 10, 2009 | 09:15 PM
jtarp's Avatar
I would go OEM for sure. Delphi/AC Delco
Hal Fisher
Sep 30, 2015 09:03 PM
CARiD
Sep 30, 2015 05:44 AM
surreybrad
Sep 29, 2015 09:00 PM
colts0455
Sep 27, 2015 01:07 PM
autoxr166
Sep 25, 2015 04:21 PM
