What type of MAF sensor?
Old May 12, 2008 | 12:10 AM
KajunKadillac's Avatar
Well my current MAF sensor is fried, should i get a remanufactured one or a new one? regardless of which i get, when i rebuild my engine im going to descreen it. But i would like peoples inputs? unless someone has a perfectly good one that works without problem (ill check parts for sale/wanted soon). Thanks in advance for your opinions.
Old May 12, 2008 | 12:21 AM
LSWHO's Avatar
Just pick up a used one. STOCK used one.
Old May 12, 2008 | 12:28 AM
bombebomb's Avatar
Whatever you do get a stock one.
Old May 12, 2008 | 01:01 AM
So who makes the stock MAF? i found this one.
Cardone Remanufactured MAF
Old May 12, 2008 | 01:44 PM
Another reason why i suspect my MAF is dead or dying because the the OBD II codes are flashing at me reading P0171, P0174 codes. both saying system running lean bank 1 and bank 2. This happened first when i had my friends descreened MAF. so i got my old one back, and ther codes went away, the codes came back on when i was doing Acceleration test, so i plugged this machine to test it, and did every test possible only to yield either no response, or very little.
Old May 12, 2008 | 02:47 PM
reamo04's Avatar
do not descreen your maf, and you wont have as many little problems. A maf with the screen is a LOT easier to tune than one without as well. If you plot everything, a screen maf will have a nice linear line of regression, where a descreen one with have no line and everything will just be randomly scattered.
Old May 12, 2008 | 02:56 PM
caldercay's Avatar
Do not de-screen it. And use a stock unit.
andrewcapps82
May 19, 2015 10:11 PM
Dzmaro
May 7, 2015 09:33 AM
pete53
Dec 9, 2014 07:31 AM
Rich_z28
Sep 8, 2002 12:00 AM
