What tubes to I need with Hoosier QTP 28x11.5x15?
Old Jan 28, 2003 | 05:38 PM
Kain's Avatar
What tubes to I need with Hoosier QTP 28x11.5x15 on a 15x8 Telstar. I know they'll bulge a little bit.
Old Jan 28, 2003 | 06:14 PM
streetbad's Avatar
Tubes are for bicycles. I would try to avoid them on a car. They add a lot of unnessary weight. They cause a lot of balance problems.
Old Jan 28, 2003 | 06:25 PM
TedH's Avatar
I'm guessing the following will help. You can call them for confirmation prior to ordering...
http://www.mickeythompsontires.com/strip_tubes.html
BTW: I run tubes. The manufacturer recommends tubes. I use rim screws and I don't want my tires to leak. Tubes do make balancing a bit more difficult but it is the right way to do it. Use plenty of talc when you intstall the tubes. Don't let a discount auto place do it, take them to a truck shop becasue those guys generally know something. Tubes will make your tires last longer too.
Old Jan 28, 2003 | 06:44 PM
Kain's Avatar
Hmmm. Now I'm debating. I'm probably not going to run less that 14 psi in the tires. And I'm not going to go with rim screws. Hmmmm.
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
