What tool for opti screws?
I got a new opti from auto zone. It turns out that it is only part of it. I have to take the cap off the old one. I cant find the tool to take out the screws. They are an inverse torx #4. I bought a 1/4 inch drive socket that was #4 from snap-on and it will get 2 of the screws but the other 2 or recessed. How does everyone else take these apart? Thanks.
I bought the inverted torx deep socket set from snap-on, it was 5 sockets. The sizes needed for the opti were in the set, I think it was like 55 bucks for the 5 sockets. in my 2 year old catalog it had a caption under the picture that said "designed especially for the ABITS distributor." (Angle-Based Ignition Timing System) GMs actual name for the opti. do not destroy or overtighten those screws, they are triobular and some really, really screwed up thread that you will NOT be able to find. been there.... Went to ace and a nuts/ bolts/ manufacturer / distribution center. I conviently lived about 8 feet away from it at the time
Easiest way is to take a screw out of the throttle body plate, double nut it, and use vice grips on it[it'll take the dist cap screws off...]
If you need to do the rotor I believe those are T9 torx [T8 will work but is 'loose']
The socket I got from snap on truck worked for all four screws. Mine cost 9 bucks. Those guys are usually pretty cool. Take the opti with you and see if they got a deep socket #4 that you can use. Good luck.
Originally posted by Tim240z
Thanks Dave!!! Actually thinking about selling it to fund my latest project ( I enjoy building more than driving!!):
BTW: If anyone gets forbidden when they click on that link, just hit the refresh button...
Here's what you need. I found one at my local Parts Plus for $5.99
http://www.lislecorp.com/tool_detail.cfm?detail=377
Aug 24, 2015 06:41 AM
88IROC_Z
Jul 22, 2015 11:38 PM
Catmaigne
Jul 14, 2015 05:17 PM
