what timing chain for a 94?
Old Dec 7, 2004 | 09:44 PM
hawk232's Avatar
i have a 94 and dont want to "upgrade" to the vented opti ( i will be going ltcc) and i was wondering what timing chain i can use (besides the lt4 one) that will work with my stock timing cover (i dont mind modifying it or whatever, as long as i dont have to buy another opti and cover) i will be using and electric pump so that shouldnt be an issue either.
Old Dec 7, 2004 | 10:34 PM
Z284thgen's Avatar
Re: what timing chain for a 94?
http://web.camaross.com/forums/showthread.php?t=322565
Old Dec 8, 2004 | 07:37 AM
You can't use an LT4 set with a non-vented opti. There is nothing there to drive your opti. To use a non-vented opti, you are stuck with the stock gear or there are a couple of people that make a very high dollar stronger replacement gear.
Old Dec 8, 2004 | 07:47 AM
ibanez6rg's Avatar
I'm using the Cloyes "True" double-roller.
Old Dec 8, 2004 | 08:09 AM
hawk232's Avatar
so in other words, i HAVE to convert to vented opti if i want to use a decent chain?
Old Dec 8, 2004 | 08:33 AM
Tommy'Z 6speed's Avatar
I was in the same boat. I ordered the Cloyes true roller only to find it wasn't splined. I wound up using a Dynagear from Advance.
Old Dec 8, 2004 | 06:57 PM
Pretty much so.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
