ESP Wire
Re: ESP Wire
On the 3rd Gens, there was an Electronic Spark Timing (EST) circuit, involving the signal from the PCM, but in the LT1's they changed it to the Ignition Control Circuit.
The Ignition Control wire runs from PCM terminal A13, to the IC Module terminal B, and is white.
My psychic advisor told me there would be days like this.
I think it might be a trick question. If you had ESP, you would already know the answer.
Re: ESP Wire
Originally Posted by ElectronBlueC3
Which set of wires coming out of the PCM would those be? Part of the grey, black, blue, or red group?
Drtryder
04-22-2015 04:17 PM
Brandon Wittmer
12-03-2014 09:28 PM
