What temperature should the fans start wrkn..
Old Sep 4, 2012 | 08:28 AM
Luis350lt1's Avatar
Hi guys,
At what temperature should the fans start working? car is running too hot... I own a 1995 Z28 Vert. Thanks in advance
Old Sep 4, 2012 | 08:45 AM
RamAir95TA's Avatar
Re: What temperature should the fans start wrkn..
What is your definition of too hot? Stock fans don't come on until 227 degrees (235 for the high speed).
Old Sep 4, 2012 | 01:25 PM
Cooling fans operation and testing
Old Sep 4, 2012 | 04:11 PM
Luis350lt1's Avatar
they are turning on apparently at the correct factiry temperature. But it goes up until 250 degrees then it winds down, the fans switch of at 220 degrees or so and then the temp goes back up to 250 degrees. Maybe the radiator? I have a 160 stat, factory pump and factory fans but I have a Be Cool aluminum radiator that I installed a few years back.
Old Sep 4, 2012 | 06:30 PM
moparman's Avatar
Is the front air dam still on the car? It's normal for the car to heat up while sitting still, or in slow moving traffic.
Old Sep 6, 2012 | 02:11 PM
CstIrnFst's Avatar
As stated above, it's normal for these cars to run 'hot'. If you start the car, keep it in park, with the A/C off, the fan won't come on until it's just below the red line. This is normal.
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
