What temp does your LT1 run at
Old Jun 9, 2004 | 04:11 PM
  #16
MikesGreenZ28's Avatar
my temp stays the same wheather i have the a/c on or not, so i am thinking its the sensor that feeds the gauge that is shot. *i hope anyways* that it is not something major.
Does anyone know if you can replace this from the top of the engine? I got the other one from the top but this one looks a bit tricker, i seen the diagram on the shoebox site.
Old Jun 9, 2004 | 04:14 PM
  #17
Also how can I tell if my car has a different PCM Chip? its a 94. Anyway of reseting it?
Old Jun 9, 2004 | 05:21 PM
  #18
ok i think i have the fan problem figured out because there are different stages, the first stage is almost always on and then it gets louder as the engine heats up.
I can hear the fans comming on and off but the gauge still sits in the same spot, so I am guessing its that sensor? is there anything else that could cause it to do that?
Old Jun 9, 2004 | 05:27 PM
  #19
white97z/28's Avatar
Heres a question. If i wanted to run cooler at the track, could i just take the air pump fuse out so my fans would come on all the time?? or would this hurt performance in some way?
Old Jun 9, 2004 | 05:38 PM
  #20
youw ouldnt want to do that, you would be better off hooking up a switch to control the fans.
Old Jun 9, 2004 | 05:42 PM
  #21
simple's Avatar
fan turn on lowered in the pcm (190*) and CSI pump, car barely goes above the 1st 1/4 mark on the guage, no matter if i'm sitting in traffic or highway
stock thermostat
AlaskaZ28
Jan 1, 2015 12:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
