What is this tapping noise?
Old Aug 29, 2004 | 02:50 AM
Gripenfelter's Avatar
It comes from the passenger side valve cover.
Its intermittent. About every 5 secs or so.
Its just a single loud tap.
Sometimes followed by a surge in the idle.
My car sometimes idles very low when I slow down to a stop.
I've had the valve covers off and run the car and its none of the rockers. I even loosened and re-tightened the rockers.
It sounds like its coming from right near the top of the valve train or just under them.
Bad lifter?
Showing 1 degree of retard.
Any guesses?
Old Aug 29, 2004 | 03:14 AM
94 CAMRO Z28's Avatar
Re: What is this tapping noise?
My guess would be a lifter on its way out.
Aaron
Old Aug 29, 2004 | 11:43 AM
Broken valve spring? I have a double coil.
Old Aug 29, 2004 | 01:27 PM
I dont know that a broken vavle spring would be intermittent though. I would think you would hear it almost constantly not every 5 sec. or so.
Aaron
Old Aug 29, 2004 | 01:39 PM
I'll go check and report back
Old Aug 29, 2004 | 02:27 PM
indieaz's Avatar
Make that another vote for lifter. Spring should be a constant sound.
Old Aug 29, 2004 | 05:22 PM
TigerWoodsJr's Avatar
I would look into that lifter asap. I had a lifter get a flat spot on it. The noise changed with idle. I only put like 30 miles on it after i noticed the sound...bad idea I know...and it ate through the came so I had to get a new one. Pulling the intake manifold off is nothing compared to having to take it apart for a new cam.
Old Aug 29, 2004 | 11:13 PM
Well its not the valve spring.
Must be the lifter.
I've put well over 200 miles on it. At first it was a very faint tap. Recently its gotten louder. I put probably 30 miles on it after it got loud.
Definately pulling the intake off tomorrow.
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
