What are symptoms of a psychotic MAP Sensor?
Old Apr 19, 2003 | 10:34 PM
firebirdslickg's Avatar
Just curious as to what are known symptoms of a MAP sensor that's going bad
Old Apr 19, 2003 | 10:36 PM
Rodrigues's Avatar
Not too sure, if you suspect that it is going bad, just try cleaning it out or replace it. It's not that hard to do, or a lot of money if you wanted to replace it.
Old Apr 19, 2003 | 11:36 PM
Jason Dove's Avatar
Hooking up a scanner and seeing bad MAP sensor readings? Sorry, I believe the symptoms could be very different depending on what's wrong with the sensor.
Old Apr 19, 2003 | 11:37 PM
T/A#4's Avatar
Lightbulb
When you gas milage takes a dump that's a sure sign ........
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
zajones
Jul 30, 2015 02:18 PM
asilomar244
Jul 12, 2015 05:53 AM
