what studs for RR on hotcam kit?
Old Feb 11, 2007 | 02:11 PM
maro z28's Avatar
Did 3/8" or 7/16" studs come w/ LT4 hotcam kit? On a side note are LT4 hotcam kits all the same?
Old Feb 11, 2007 | 02:35 PM
nodnarb481's Avatar
3/4" i believe and yes i believe they are all the same
Old Feb 11, 2007 | 02:37 PM
2000GTP's Avatar
3/8 stud, SA rockers.
Old Feb 11, 2007 | 03:25 PM
maro z28's Avatar
Yeah, I just found out. Car comes with factory 3/8" studs and probably the guy who ordered the hotcam kit bought the RRs for 3/8" studs. So, I 'm gonna have to get new RRs and 7/16"(damn it!). What do I have to do, drill out the holes a bit to accept bigger studs? Where can I buy the studs and how much are they?
Old Feb 11, 2007 | 03:36 PM
maro z28's Avatar
just found em at Thunder for $65(ARP Pro Series). This sound good w/ Comp Pro Magnums for use w/ cam similar in size to some of the LE2 cams?
Old Feb 11, 2007 | 04:07 PM
If you got the whole HOT cam kit, why do you need to change anything?
The head side of the stud is 7/16 on both the 3/8 and 7/16 studs, so there is nothing to do but unscrew the old and screw in the new.
Old Feb 11, 2007 | 04:24 PM
maro z28's Avatar
yeah but the RRs I have now accept 3/8" studs, won't I need new RRs to accept 7/16" studs? They are listed seperately on Thunder's website.
Old Feb 11, 2007 | 06:32 PM
SnakeOiler's Avatar
Do you have 7/16" studs installed on your engine? Because, up above you state that you need to buy some. ????
Old Feb 11, 2007 | 06:50 PM
maro z28's Avatar
No, I believe I have the RR for the 3/8" studs.
Old Feb 11, 2007 | 07:49 PM
Z-RATED94's Avatar
I would sell the rockers you have, use the 7/16s studs and a new set of 7/16 ProMag rockers for a solid set-up.
Old Feb 11, 2007 | 08:24 PM
seawolf06's Avatar
He's converting from the hotcam kit to another setup. He should have mentioned this first to clear it all up.
The bottoms of the studs are the same as stock and the go right into the head, no drilling. The tops are different sizes.
I was recommended to use the 7/16" studs with bigger rockers. Get the NSA pro mag rockers, ARP studs and GMPP guideplates.
Old Feb 11, 2007 | 08:37 PM
cdb95z28's Avatar
Check the parts for sale forum.......Pro Mags for sale
Old Feb 11, 2007 | 08:47 PM
nodnarb481's Avatar
ha wow.. i meant to say 3/8 my bad
Old Feb 11, 2007 | 08:54 PM
seawolf06's Avatar
http://web.camaross.com/forums/showthread.php?t=501542
Old Feb 11, 2007 | 09:13 PM
Yeah, the whole thing made little sense.
