What is the strongest Pinion Bearing?
Old Apr 22, 2003 | 06:26 PM
96RamAir's Avatar
Question What is the strongest Pinion Bearing?
Who makes the strongest pinion bearing for a stock 10-bolt F-body rear end? Surely aftermarket ones are stronger than GM bearings. I seemed to have worn out the pinion bearing that is in the housing, not the one on the pinion itself. Is there a stronger one? A race version?
Old Apr 22, 2003 | 07:04 PM
MYT30TH's Avatar
"Timken" bearings have long been known for there superior quality.
Old Apr 22, 2003 | 10:24 PM
96RamAir's Avatar
Any idea on part numbers, or where to buy these?
Old Apr 23, 2003 | 08:09 AM
96RamAir's Avatar
Unhappy
Anyone?
Old Apr 23, 2003 | 11:29 AM
boydst's Avatar
The Autozone chain of stores carries Timken bearings. The 10 bolt is quite common, and they should have them there. If not, you can usually find a local bearing distributor. It's worth the extra couple bucks.
Steve, 93Z
Old Apr 23, 2003 | 11:36 AM
thelategreatz28's Avatar
Doesnt Moser make some heavy duty **** for rear ends? If ya then they sell in summit.
Old Apr 23, 2003 | 12:10 PM
Tommy'Z 6speed's Avatar
I think the OEM bearing is Timken (mine is anyway).
Old Apr 23, 2003 | 02:11 PM
96RamAir's Avatar
I guess I'll swing by AutoZone. Hopefully they will be as good or better than stock. Then again the stock one may be Timken.
Old Apr 23, 2003 | 02:20 PM
FireAm94's Avatar
Stock replacement timken should do fine. How many people have you actually heard of having an outer pinion bearing fail? Not that many....you should be fine.
Joe
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
