What are the stock cc on LT4 heads???
Old Apr 19, 2005 | 10:41 PM
  #16
texasTA's Avatar
Re: What are the stock cc on LT4 heads???
Okay the Intake Centerline (ICL) is 107.8
Old Apr 19, 2005 | 10:43 PM
  #17
texasTA's Avatar
Originally Posted by 94formulabz
The larger valves reduced the CCs, but if jorden deshrouded the valves (99% chance he did) then that increased the chamber size. Bottom line is that you need to get them checked because these types of operations can greatly effect the chamber size.
Yes the machine shop should be able to if they aren't total hacks. Basically you flip the head over and fill it up with liquid and measure it with a syringe or some other measureing device.
You may want to ask jordan though. He may have measured them all to make sure they matched. You don't want one chamber smaller then all the rest and always detonating.
-brent
Well you see, Jordon has been telling me that the heads are stock LT4 ccs, so that is why I assumed that even though what he has done, they are still 54.4cc
I sent Jordon an email today at work, and I am looking forward to what he thinks. I totally trust Jordon, and I will do whatever he thinks we should do.
  #18
94formulabz's Avatar
okay, you have 4 degrees advance then. LSA-ICL.
Do you have the .006 duration numbers?
Old Apr 19, 2005 | 10:47 PM
  #19
texasTA's Avatar
As in the head flow numbers?
Old Apr 19, 2005 | 11:04 PM
  #20
no, cam duration. Card should have duration at .006" lift and .050 tappet lift.
Old Apr 19, 2005 | 11:09 PM
  #21
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Hey Matt.. The .006 duration would also be listed under an "advertised" heading. I'd imagine it to be in the 30X-31X area... Like a "CC306" is 230/244 @ .050.. Advertised #'s are like a 292/306 I believe. <- Just for comparison's sake.
Old Apr 19, 2005 | 11:17 PM
  #22
texasTA's Avatar
The only thing I got on the entire page from Cam Motion is the duration at .05, which is Intake = 245.7 Exhaust = 251.1
Old Apr 19, 2005 | 11:33 PM
  #23
Does it reference the intake lobe as x-2461?
That lobe has an advertised duration of 300.
This puts your IVC at 77.8 degrees ABDC
Assuming your static was calculated correctly at 12.2:1 (which i doubt because i doubt they are 54.4 cc chambers)
Your dynamic compression would be a very safe 8.64:1 and i would actually recommend you mill the heads down some more.
Check with jorden on the chamber size though. Discuss compression with him since you trust him, he should have some input.
-brent
Old Apr 19, 2005 | 11:35 PM
  #24
texasTA's Avatar
The only thing even close is Intake lobe lift = .40917 in. and intake lobe area= 32.99 in * DEG
It also lists lobe size bc/ht IN: .975 and EX: 1.015
Old Apr 19, 2005 | 11:39 PM
  #25
Whoa, i was looking at hydraulic lobes. Is that a solid roller? Yes i see it is, my bad.
If so then r-2481 and the adv duration is only 281 and your compression will be too much *if* those static numbers where correct.
http://www.cammotion.com/Portals/fee...a1a/Binder.pdf
Edit* Okay, I'm just ran that cam lobe with an IVC of 68.3 with both assumed static compressions.
12.2:1 -> 9.44 Dyn
11.8:1 -> 9.14 Dynamic (still a lil too high for pump gas)
My advice, talk to jordan.
g'night
-brent
Old Apr 20, 2005 | 08:42 PM
  #26
arnie's Avatar
Originally Posted by LT4383
Untouched they should be 54.4cc......
I take it you have checked LT4 heads yourself? As worded that statement is not entirely accurate! It is no wonder there is so much misinformation floatin' around. Helpful people just guessing.
Originally Posted by 1-bad-z28
This question was up about 2 weeks ago. You are about to get 15 different answers.
That is cuz so few know what they are talking about.
Originally Posted by chevyguy3
stock LT1= 54cc
stock LT4= 54.4cc
That is an incomplete answer. So as such, it is at least misleading.
Doing a search is a good idea. To save you some trouble, search under 'Arnie'. Have no idea how many of those threads have been deleted from archive due to date issue, but those that remain have one thing in common, consistency. The info is based on actual checking, not guessing. This goes for the LT1 as well as LT4 heads. From now on, when someone submits an answer to this question, it may be a good idea, to inquire whether they actually checked the head they are referring to, or just echoing what someone else posted elsewhere. It will help stem some of the misinformation being posted.
Old Apr 20, 2005 | 10:30 PM
  #27
your engine builder should CC the heads himself to know exactly what he is dealing with
Arnie,
I definitly agree with everything you said about the spread of shaky information, but to be fair to chevyguy, he also did post the above statement immediately after the chamber sizes he listed. And as i previously stated I do agree with chevyguy that the builder should just verify it instead of guessing, which is in a sense what you're saying as well.
-brent
TexasTA, did you talk to Mr. Musser?
Old Apr 21, 2005 | 04:29 AM
  #28
chevyguy3's Avatar
Arnie, i did a search and in multiple threads you posted having measured stock LT1 chambers as being right around 54cc (+/- 3-4 tenths you say), so i dont understand what your problem is with the information that was posted?
i dont currently have any un-molested LT1 castings laying around, but i do have a set of untouched LT4 heads laying in the basement that i will measure when i get home from work just for the hell of it.
Old Apr 21, 2005 | 08:41 AM
  #29
LT4383's Avatar
Damn Arnie didn't mean to step on your toes so hard...but maybe you should go to all these sites and inform them how their data is wrong as well with these UNTOUCHED LT heads.
I do agree that the porter had better cc a head after working on the chamber or doing any valve work.
LT4 head data
LT4 head data
LT4 head data
head data
Old Apr 21, 2005 | 04:50 PM
  #30
arnie's Avatar
.... but to be fair to chevyguy, he also did post the above statement immediately after the chamber sizes he listed.
To be fair, I can read. The content of my previous post stands.
I did a search and in multiple threads you posted having measured stock LT1 chambers as being right around 54cc (+/- 3-4 tenths you say), so i dont understand what your problem is with the information that was posted?
The figure above still stands, as well as figures themselves, in your previous post, being accurate. Your account of the figures is good, but you left out important details. Thus, as posted, opens the door to a misunderstanding. As such, I considered the figures taken out of context. Without 'qualifying', or explaining the figures in more detail, as I took the time to do, in numerous previous posts, both here and in 'Advanced', those that read the post, will leave with a distorted viewpoint. In my previous posts, I used figures... 54.0, 54.4, another but different 54.0, as well as a range of figures, all in the same post. Why? That was necessary to 'paint' a true picture, and allow the reader to walk away with a clear understanding of the figures presented. Your response didn't present those (accurate) figures in the same 'lite' or context as I did. As such, although accurate, those figures may not (depending on the head) represent figures people discover for themselves, if they were to check their heads.
You aren't, intensity is mute. The problem with the misinformation I am referring to, is two fold. Too many sites, (both info and retail sales) including ones you linked, spread misinformation and/or inaccurate info, because they do not qualify those figures. Intentional or not, it's also a mute point. Second, well intentioned people post/spread this misinfo with no personal verification of any kind, whether it is referenced from a website or another thread/post. Because it is on any given website, it is unquestioned regarding it's accuracy. People blindly believe info obtained from the net, is automatically fact.
Bottom line guys? After reading my previous posts, those that check both LT1/4 heads will know what to expect when they check, and when #s don't jive with figures displayed on websites, they'll know why. For that reason, I recommend my archved posts for you guys. Although Chevyguy appears familiar with my archived posts, I believe he just needs to refresh himself with the details. My posts were not intended to discount or dismiss your TRUE intention(s) above.
