What are the stock cc on LT4 heads???
Re: What are the stock cc on LT4 heads???
Originally Posted by 94formulabz
The larger valves reduced the CCs, but if jorden deshrouded the valves (99% chance he did) then that increased the chamber size. Bottom line is that you need to get them checked because these types of operations can greatly effect the chamber size.
Yes the machine shop should be able to if they aren't total hacks. Basically you flip the head over and fill it up with liquid and measure it with a syringe or some other measureing device.
You may want to ask jordan though. He may have measured them all to make sure they matched. You don't want one chamber smaller then all the rest and always detonating.
-brent
-brent
I sent Jordon an email today at work, and I am looking forward to what he thinks. I totally trust Jordon, and I will do whatever he thinks we should do.
Hey Matt.. The .006 duration would also be listed under an "advertised" heading. I'd imagine it to be in the 30X-31X area... Like a "CC306" is 230/244 @ .050.. Advertised #'s are like a 292/306 I believe. <- Just for comparison's sake.
Does it reference the intake lobe as x-2461?
That lobe has an advertised duration of 300.
This puts your IVC at 77.8 degrees ABDC
Assuming your static was calculated correctly at 12.2:1 (which i doubt because i doubt they are 54.4 cc chambers)
Your dynamic compression would be a very safe 8.64:1 and i would actually recommend you mill the heads down some more.
Check with jorden on the chamber size though. Discuss compression with him since you trust him, he should have some input.
-brent
-brent
The only thing even close is Intake lobe lift = .40917 in. and intake lobe area= 32.99 in * DEG
It also lists lobe size bc/ht IN: .975 and EX: 1.015
Whoa, i was looking at hydraulic lobes. Is that a solid roller? Yes i see it is, my bad.
If so then r-2481 and the adv duration is only 281 and your compression will be too much *if* those static numbers where correct.
http://www.cammotion.com/Portals/fee...a1a/Binder.pdf
Edit* Okay, I'm just ran that cam lobe with an IVC of 68.3 with both assumed static compressions.
12.2:1 -> 9.44 Dyn
11.8:1 -> 9.14 Dynamic (still a lil too high for pump gas)
My advice, talk to jordan.
g'night
-brent
12.2:1 -> 9.44 Dyn
g'night
-brent
Originally Posted by LT4383
Untouched they should be 54.4cc......
Originally Posted by 1-bad-z28
This question was up about 2 weeks ago. You are about to get 15 different answers.
Originally Posted by chevyguy3
stock LT1= 54cc
stock LT4= 54.4cc
stock LT4= 54.4cc
Doing a search is a good idea. To save you some trouble, search under 'Arnie'. Have no idea how many of those threads have been deleted from archive due to date issue, but those that remain have one thing in common, consistency. The info is based on actual checking, not guessing. This goes for the LT1 as well as LT4 heads. From now on, when someone submits an answer to this question, it may be a good idea, to inquire whether they actually checked the head they are referring to, or just echoing what someone else posted elsewhere. It will help stem some of the misinformation being posted.
your engine builder should CC the heads himself to know exactly what he is dealing with
I definitly agree with everything you said about the spread of shaky information, but to be fair to chevyguy, he also did post the above statement immediately after the chamber sizes he listed. And as i previously stated I do agree with chevyguy that the builder should just verify it instead of guessing, which is in a sense what you're saying as well.
-brent
TexasTA, did you talk to Mr. Musser?
Arnie, i did a search and in multiple threads you posted having measured stock LT1 chambers as being right around 54cc (+/- 3-4 tenths you say), so i dont understand what your problem is with the information that was posted?
i dont currently have any un-molested LT1 castings laying around, but i do have a set of untouched LT4 heads laying in the basement that i will measure when i get home from work just for the hell of it.
Originally Posted by arnie
I take it you have checked LT4 heads yourself? As worded that statement is not entirely accurate! It is no wonder there is so much misinformation floatin' around. Helpful people just guessing.
That is cuz so few know what they are talking about.
That is an incomplete answer. So as such, it is at least misleading.
I do agree that the porter had better cc a head after working on the chamber or doing any valve work.
LT4 head data
LT4 head data
LT4 head data
head data
.... but to be fair to chevyguy, he also did post the above statement immediately after the chamber sizes he listed.
The content of my previous post stands.
I did a search and in multiple threads you posted having measured stock LT1 chambers as being right around 54cc (+/- 3-4 tenths you say), so i dont understand what your problem is with the information that was posted?
Damn Arnie didn't mean to step on your toes so hard...
Bottom line guys? After reading my previous posts, those that check both LT1/4 heads will know what to expect when they check, and when #s don't jive with figures displayed on websites, they'll know why. For that reason, I recommend my archved posts for you guys. Although Chevyguy appears familiar with my archived posts, I believe he just needs to refresh himself with the details. My posts were not intended to discount or dismiss your TRUE intention(s) above.
