What springs with GMPP 1.6 roller rockers?
Old Nov 6, 2006 | 04:49 PM
Unertl42's Avatar
Like it says, I just bought some GMPP 1.6 Roller Rockers and was wondering what springs I sould buy, where to buy them and price. Remember, I'm a college student, so I'm poor
Thanks,
Austin
Old Nov 6, 2006 | 04:56 PM
CustomSSI's Avatar
cheapest bet would be some LT4 springs then.. I'm guessing you still have the stock camshaft?
Old Nov 6, 2006 | 05:40 PM
seawolf06's Avatar
Agreed.
Old Nov 6, 2006 | 05:50 PM
Unertl42's Avatar
yeah, stock camshaft, where can I get LT4 springs, and how much?
Old Nov 6, 2006 | 05:58 PM
MeanGreen97Z's Avatar
gmpartsdirect sells them. 40$ new in the box.
Old Nov 6, 2006 | 06:32 PM
Unertl42's Avatar
what other parts do I need to get? Do I need retainers, caps, or is all that included in the spring set?
Old Nov 6, 2006 | 06:47 PM
The Engineer's Avatar
Your stock retainers, spring base shims will work with the LT4 springs (they are the same). Although, you should replace the valve stem seals, as they get hard with age and can leak oil. GM parts has some premium seals for the LT.
You'll need the KD valve spring compressor and a magnet to catch the locks. Also, make sure each piston is TDC on that cylinder when changing the spring and seals to make sure you don't drop a valve.
WD
http://www.cardomain.com/ride/2189634
Old Nov 6, 2006 | 08:46 PM
Dansean1's Avatar
Im running the pro form 1.6 rr's. I still have all stock valve train. I was informed that unless you get coil bind (when installing the rockers you can check for this), no need to change anything. Additionally, unless you are leaking oil, dont mess with the valve seals.
I have 90k on my motor, no problems yet. Just my .02.
By the way, I bought the LT4 valve springs and never installed them. If you do want to put them on, its a pain but good insurance I presume nonetheless.
Old Nov 6, 2006 | 09:03 PM
Unertl42's Avatar
so do I need any other parts other than caps and valve stem seals?
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
