Want to run 12's
Old Nov 5, 2006 | 09:21 PM
red1984's Avatar
Want to run 12's
I just installed 4.10 gears, pacesetter long tube headers, 2.5inch true duals, and lakewood action lift bars. How fast do you think she is?
Old Nov 5, 2006 | 10:14 PM
reamo04's Avatar
well, its a4, and you don't have a stall converter or shift kit listed, so id say a mid-low 13?
Old Nov 5, 2006 | 10:25 PM
MeanGreen97Z's Avatar
With good tires I bet you can get some low 13s. Gotta drive the hell out of it though!
Old Nov 6, 2006 | 09:54 AM
T/A-Bob's Avatar
Might want to take a look at this: http://www.ws6zxr.com/showthread.php...light=lakewood
Old Nov 6, 2006 | 10:04 AM
Javier97Z28's Avatar
Moderator
Throw a converter on it and you'll go 12's. Done.
Old Nov 6, 2006 | 10:53 AM
2000GTP's Avatar
A converter and drag radials is the surest way to get there. There was a member on here with a stock stall car with every bolt on and some weight reduction that cracked high 12s though.
Old Nov 6, 2006 | 08:58 PM
red1984's Avatar
This winter I plan on doing some trany work, install a cold air intake, roller rockers, and tires. What should I after that? cam? heads? My brother has a 1983 camaro with about 525 horse power and his Lakewood traction action lift bars work great on his car.
Old Nov 6, 2006 | 09:12 PM
JimboManJones's Avatar
If all you want is 12s, all that stuff will defintely get you there, the converter, tires and roller rockers are all you need.
Old Nov 6, 2006 | 09:23 PM
red1984's Avatar
Right now my goal is to get into the high 12's. I will do more work later when I can afford it. After talking to my brother he did bend the brackets on his Lakewood traction action lift bars. After he reinforced them he hasn't had any problems
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
